thelorry Posted August 25, 2006 Report Share Posted August 25, 2006 I have just had a service carried out on my Bora, everything was fine, however the mechanic forgot to reset the service indicator. Does anyone have the step by step process, as i know its just a case of holding down the the mileage button and then removing the key from the ignition, or something like that. Link to comment Share on other sites More sharing options...
Rustynuts Posted August 25, 2006 Report Share Posted August 25, 2006 Search, matey and you will find. Link to comment Share on other sites More sharing options...
thelorry Posted August 25, 2006 Author Report Share Posted August 25, 2006 I did search but for it but couldn't find the step by step guide! You beat me to it, cheers rustynuts! Link to comment Share on other sites More sharing options...
BITTU Posted August 25, 2006 Report Share Posted August 25, 2006 hold the left mileage resetter button down, turn on ur ignition (2 clicks) and then while still pushing down the tight burrom, hold the left one under the left down and rotate clockwise. after a couple of trys this worked for me Link to comment Share on other sites More sharing options...
benjie Posted August 26, 2006 Report Share Posted August 26, 2006 [ QUOTE ] hold the left mileage resetter button down, turn on ur ignition (2 clicks) and then while still pushing down the tight burrom, hold the left one under the left down and rotate clockwise. after a couple of trys this worked for me [/ QUOTE ] He means: 1. Press and hold the odometer button (the right-hand one) 2. Turn ignition to 'on' position 3. Turn the clock adjuster button to the right That should be it Link to comment Share on other sites More sharing options...
BITTU Posted August 26, 2006 Report Share Posted August 26, 2006 Thanks for making it a bit easier to follow... i arent too good at explaining am i? ;-) Link to comment Share on other sites More sharing options...
benjie Posted August 26, 2006 Report Share Posted August 26, 2006 You did it at 12.46AM, so I expect you were tired! I just copied and pasted from somneone else's explanation on uk-mkivs.net!! Link to comment Share on other sites More sharing options...
