kenny_boon Posted October 19, 2006 Report Share Posted October 19, 2006 Hi all, have managed to borrow vag com from a friend who hadnt yet installed it. but having tried to install it the program works, downloaded from Ross..... the cable is an ebay item i believe. when i fire everything up on the laptop and connect to the car i get a " no response from controller" message when entering "select the control module tab what have i done wrong? Link to comment Share on other sites More sharing options...
Tobes49 Posted October 19, 2006 Report Share Posted October 19, 2006 have you got the ignition on in the car? I know it basic but you have to check. If yes, Try another control module you know the car has, eg Engine or ABS Link to comment Share on other sites More sharing options...
kenny_boon Posted October 19, 2006 Author Report Share Posted October 19, 2006 yeah ign was on, tried engine and abs no joy Link to comment Share on other sites More sharing options...
kenny_boon Posted October 19, 2006 Author Report Share Posted October 19, 2006 yeah i have allowed it to access the net etc and got the drivers my usb serial port is com4 but when i do the test it says not found but com 3 is finding it ok interface : found type: serial pass-through opto/iso : no ross teck design : no Link to comment Share on other sites More sharing options...
Tobes49 Posted October 19, 2006 Report Share Posted October 19, 2006 What version have you downloaded? Most EBay leads only work with version 311.2 download here Link to comment Share on other sites More sharing options...
Hudster Posted October 20, 2006 Report Share Posted October 20, 2006 You need to make sure the lead is set up to use ports 1-4 and not anything higher. Go into Control Pane -> System -> Device Manager and have a look around. Had the same problem with my laptop. The solution was to delete the device on port 1 and then install the lead on that same port. Link to comment Share on other sites More sharing options...
Hudster Posted October 20, 2006 Report Share Posted October 20, 2006 [ QUOTE ] What version have you downloaded? Most EBay leads only work with version 311.2 download here [/ QUOTE ] check that too - mine only works with 311.2 Link to comment Share on other sites More sharing options...
kenny_boon Posted October 21, 2006 Author Report Share Posted October 21, 2006 got it working now how do i log block 115? Link to comment Share on other sites More sharing options...
Sebastian Posted October 21, 2006 Report Share Posted October 21, 2006 [ QUOTE ] now how do i log block 115? [/ QUOTE ] With a licensed version of VAG-COM. http://www.ross-tech.com/Merchant2/merch...ory_Code=VAGCOM Link to comment Share on other sites More sharing options...
kenny_boon Posted October 21, 2006 Author Report Share Posted October 21, 2006 have borrowed a laptop with full. boost seems ok as does block 120 and 020 Link to comment Share on other sites More sharing options...
UweRoss Posted October 24, 2006 Report Share Posted October 24, 2006 [ QUOTE ] What version have you downloaded? Most EBay leads only work with version 311.2 download here [/ QUOTE ] Please refrain from deep-linking directly to our files. Please link to the relevant PAGE instead, like this: http://www.ross-tech.com/vag-com/download/archives.html -Uwe- Link to comment Share on other sites More sharing options...
