sump plug
  • Please log in to reply
5 replies to this topic
#1 petewxm
petewxm
    Shank's Pony
  • Members
  • Pip
  • 8 posts
Posted 25 October 2006 - 06:45 PM
Hi,
Can anyone please help, I took the sump plug out today to drain some oil out (because a stupid garage had overfilled the oil !!!!!!!!!!) and as I was tightend the bolt, I think I must have over tightend it because it now wont tighten and it will not come out, it just spins. (no oil is leaking from it)
Has anyone got any advice of what to do,
Will a normal garage fix this or is it a job for the main dealer.
Will they drill the bolt out and re-thread it? or will I need a new sump? or is there anything I can do?
I wish I just took it back the garage now /ubbthreads/images/graemlins/frown.gif
Oh its a bora 1.9TDi 130
Thanks for any advice
Pete
#2 mulkbear
mulkbear
    Subaru Impreza WRX
  • Members
  • 2,613 posts
Posted 25 October 2006 - 07:34 PM
New sump or the sump needs to be retreaded.
A new sump is around £60 to buy from a main dealer
Vasaline on toast.....
#3 alexc
alexc
    BMW 130d
  • Members
  • 1,148 posts
Posted 26 October 2006 - 10:30 AM
Yep, just buy a replacement sump, remove and refit, also invest in a torque wrench! /ubbthreads/images/graemlins/169144-ok.gif
Posted Image
Elite Car Care - The home of quality detailing products.
#4 pingpongpo
pingpongpo
    Subaru Impreza WRX
  • Members
  • 2,828 posts
Posted 26 October 2006 - 12:19 PM
If it has to come off anyway to be replaced, why not just helicoil the thread?
#5 petewxm
petewxm
    Shank's Pony
  • Members
  • Pip
  • 8 posts
Posted 27 October 2006 - 08:13 AM
Hi Thanks for the replys, I have now got it booked into a garage on Tuesday.
I could do with having the car back on the road before then, How easy is it to replace the sump? Is it just a case of removing the bolts, replacing the gasket, bolt the new sump back on and then fill the car up with oil and away you go.
If it is easy I may have a go this weekend, I`m just looking for some advice before I do.
I`am going to invest in a touque wrench too.
Thanks
Pete
#6 alexc
alexc
    BMW 130d
  • Members
  • 1,148 posts
Posted 27 October 2006 - 11:03 AM
Thanks
Pete
Basically it's as you have described, before you make a start I suggest you check and see if you can reach all the bolts, as on some engines the bolts on the gearbox side can be very tricky to get to if you don't have the correct tools. Good luck! /ubbthreads/images/graemlins/169144-ok.gif
Posted Image
