Remster Posted November 13, 2006 Report Share Posted November 13, 2006 Any ideas? The rear wiper on my A4 1.9TDi Avant Sport won't turn off. Just keep wiping away. If I take the 30amp fuse out it stops but I then can't use any wipers front or rear as it controls the entire wiper circuit. It has always played up a little, sticking sometimes when doing it's sweep. However, on Friday it turned itself on when accelerating away from a junction an now just stays on. Help please. Link to comment Share on other sites More sharing options...
kite Posted November 13, 2006 Report Share Posted November 13, 2006 could be a fault on the stalk. vagcom check may show the fault. Link to comment Share on other sites More sharing options...
Remster Posted November 13, 2006 Author Report Share Posted November 13, 2006 Not got access to vagcom i'm affraid. It's either switch on the stork, solanoid or something to do with connections on the motor. I recall reading somewhere about water/dirt ingress causing problems with connections to the motor. Anyone else? Link to comment Share on other sites More sharing options...
UBM Posted November 13, 2006 Report Share Posted November 13, 2006 Sounds like the switch on the wiper stalk has locked on the on position - can you prise the microswitch on the stalk to the off position with a paper clip of something ? Link to comment Share on other sites More sharing options...
