Tarmac_Terrorist Posted November 19, 2006 Report Share Posted November 19, 2006 I shall shortly have a couple of fire extinguishers (one for each car)and I wondered if anyone else had found a succesful place to mount them. The obvious place is in the boot in place of where the dealers strap in the spare oil. With safety in mind, should they be placed inside the car somewhere...I seem to remember that on older beemers they had them mounted just under the front of the drivers seat - presumably easy to get at if your trapped inside a burning car? Any thoughts / examples welcome Link to comment Share on other sites More sharing options...
Chungster Posted November 19, 2006 Report Share Posted November 19, 2006 That's a bit serious isn't it in a normal road car? Can understand if it was highly modified extra but it's not is it?? Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted November 20, 2006 Author Report Share Posted November 20, 2006 Nope, the car isn't modified - just feel its a good idea to carry one in case of accident etc & resulting fire...may also help to save someone elses life one day..who knows I also keep a small extinguisher upstairs at home and one downstairs - you never know! Link to comment Share on other sites More sharing options...
scillyisles Posted November 20, 2006 Report Share Posted November 20, 2006 I've mounted mine in the boot on the left hand side where the rubber straps are. You can under the screw holding the rubber strap and use it to mount a fire extinguisher mounting bracket. Funnily enough the one I use is a BMW fire extinguisher kit. I'd agree about carrying a fire extinguisher - a little known fact is that modern cars are much more prone to fires than older models due to high pressure fuel injection systems, air con systems e.t.c. Link to comment Share on other sites More sharing options...
Snoopy Posted November 21, 2006 Report Share Posted November 21, 2006 As VW sell them they may even have a proper bracket for them. I know they did for mk1/mk2 golfs and it mouted to the front of the seats. Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted November 21, 2006 Author Report Share Posted November 21, 2006 I'll contact VW about that - best place to mount one in my opinion but I suspect that driver leg safety in the event of a serious impact, may have forced them to change their minds these days. If not I guess I may need to opt for the boot location as mentioned above Link to comment Share on other sites More sharing options...
stevie_d Posted November 22, 2006 Report Share Posted November 22, 2006 Mate, I've got one and I've placed it in the glove box. You REALLY don't want to be getting out and running to the boot to faff around in there if your car's on fire mate! Anyway, I think it's a sensible idea, as I've had to use mine to help a fellow petrolhead out and you never know when you'll be first on scene at an accident Link to comment Share on other sites More sharing options...
Skidmark Posted November 22, 2006 Report Share Posted November 22, 2006 On the floor in front of the front passenger seat [dont foget seat movement]......... ........doesn't look too good, but easier for driver to get at if his/her feet at trapped with impact damage. Will need a good restraint system to stop it flying about in an accident. Not much use in the boot IMHO cheers Link to comment Share on other sites More sharing options...
scillyisles Posted November 22, 2006 Report Share Posted November 22, 2006 Most (if not all) fires in modern cars start in the engine compartment and to put them out I believe that the recommended procedure is to release the bonnet retaining catch (but not open the bonnet) and then direct the fire extinguisher into the engine bay. To do this you need to be out of the car - in fact the first thing you should do if a car fire is suspected is to get your passengers and yourself out of the car asap. In this case having the fire extinguisher readily available in the boot does'nt really add any significant delay and probably makes no difference whatsoever. Link to comment Share on other sites More sharing options...
stevie_d Posted November 22, 2006 Report Share Posted November 22, 2006 This much is true, but if your car is on fire and you're trapped inside then...Also, if your car is on fire and you're able to get out then it's easier to reach into the glove box and get it, rather than go into the boot and get it. Also, what happens if you're on a road trip holiday and your boot is full of luggage... Anyway, as said above, best secure it, erm, securely in case of an accident, as you really don't want a heavy piece of metal to be flying about inside your car Link to comment Share on other sites More sharing options...
Snoopy Posted November 22, 2006 Report Share Posted November 22, 2006 [ QUOTE ] On the floor in front of the front passenger seat [dont foget seat movement]......... ........doesn't look too good, but easier for driver to get at if his/her feet at trapped with impact damage. [/ QUOTE ] I know on the mk1/2 Golf version the mounting bracket is bolted to the seat runner so moves with the seat. Link to comment Share on other sites More sharing options...
fresco1 Posted November 22, 2006 Report Share Posted November 22, 2006 [ QUOTE ] Mate, I've got one and I've placed it in the glove box. You REALLY don't want to be getting out and running to the boot to faff around in there if your car's on fire mate! Anyway, I think it's a sensible idea, as I've had to use mine to help a fellow petrolhead out and you never know when you'll be first on scene at an accident [/ QUOTE ] Back home, my cousin had a major loss of control at speed (alcohol was involved)and ended up embedded in a motorway barrier on a junction (the concrete pointy bit). Car burst into flames, he was trapped (roof buckled down and pinned him by the scalp believe it or not). A passing motorist with a fire extinguisher kept the flames at bay while the emergency services arrived. All great and sounds positive, except m'cous' got something like 40% burns and was paralysed from the chest down .... He reckons the fire extinguisher trick kept him alive, but in fairness he rather wishes it hadn't been used ... (Sorry for dismissal story!) Link to comment Share on other sites More sharing options...
Michael 1 Posted February 26, 2012 Report Share Posted February 26, 2012 (edited) The glove box would not be a practical area for a fire extinguisher in the event the car gets hit from the passenger side and the resulting damage can trap the fire extinguisher inside the glove box where it could not be accessed in the event of a fire. The best place to mount a fire Extinguisher would be as close to the center of the vehicle as possible where it can be accessed easily by any passenger in the vehicle and should be properly mounted upright in a vertical position and not allowed to be loose inside the vehicle because it could become a missile in the event of a collision and could injure or kill anybody within its path, also it could explode in the event that the tip gets broken because the contents are under tremendous pressure. Edited February 26, 2012 by Michael 1 Link to comment Share on other sites More sharing options...
Luke Posted March 11, 2012 Report Share Posted March 11, 2012 What is it with these posts recently. An answer to a question asked 5-6 years before?! Link to comment Share on other sites More sharing options...
