ChrisGoulding Posted January 7, 2007 Report Share Posted January 7, 2007 Can anyone give me reasonable price that I might be charged for changing the timing belt on my 02 Golf MK4 GT TDI PD130. Does it make any difference that the ecu has been remapped with the REVO software to make it 180bhp? Link to comment Share on other sites More sharing options...
Rustynuts Posted January 7, 2007 Report Share Posted January 7, 2007 Reasonable would be somewhere round the £175 - £225 mark for an independent, and add £50 - £80 for a main dealer. Depends on the location in the UK really. Also, make sure they know what they're doing. Certain threads on here from people who didn't know what they were doing leads to problems. ECU remap should make no difference. Link to comment Share on other sites More sharing options...
Mook Posted January 7, 2007 Report Share Posted January 7, 2007 As per Rusty's post with the pricing - if you use an independent, make sure you know them or you have a referral from someone you know. Remap etc. won't make any difference to the cost of having it done. Link to comment Share on other sites More sharing options...
ChrisGoulding Posted January 7, 2007 Author Report Share Posted January 7, 2007 Thats much cheaper than I thought it would be. Better get it done as it overdue and knowing my luck, it will snap. Cheers once again. Link to comment Share on other sites More sharing options...
meriafel Posted January 7, 2007 Report Share Posted January 7, 2007 Presuming your Golf 130 PD is the same as my 52 Passat 130 PD?.........don't forget to have the cambelt tensioner changed as well. As the power steering belt and auxilliary belt also have to come off, have new ones fitted rather than refit the old ones. Above all have only genuine VW parts fitted they aren't expensive and often cheaper than aftermarket. Cambelt replacement is such an important item that personally I would only entrust to a known VW dealer. If something does go wrong you probably have a better chance of a satisfatory conclusion, plus you get a years warranty on the work. Why chance it to save a few quid! If it's the original cambelt and over 4 years old it's already overdue! (No cnnections with VW!) Link to comment Share on other sites More sharing options...
teash Posted January 7, 2007 Report Share Posted January 7, 2007 Goulders have you tried Awesome GTi in Manchester for a price, i`m pretty sure they do an 'all in' price, belt, waterpump and tensioners Link to comment Share on other sites More sharing options...
Snoopy Posted January 7, 2007 Report Share Posted January 7, 2007 [ QUOTE ] As per Rusty's post with the pricing - if you use an independent, make sure you know them or you have a referral from someone you know. [/ QUOTE ] Same for VW dealers too. I know one who screwed this up on a passat and would not admit they were responsible. Link to comment Share on other sites More sharing options...
vindaloo Posted January 8, 2007 Report Share Posted January 8, 2007 [ QUOTE ] Goulders have you tried Awesome GTi in Manchester for a price, i`m pretty sure they do an 'all in' price, belt, waterpump and tensioners [/ QUOTE ] I'd trust Awesome more than a VW dealer any day Link to comment Share on other sites More sharing options...
Tobes49 Posted January 8, 2007 Report Share Posted January 8, 2007 [ QUOTE ] Presuming your Golf 130 PD is the same as my 52 Passat 130 PD?.........don't forget to have the cambelt tensioner changed as well. As the power steering belt and auxilliary belt also have to come off, have new ones fitted rather than refit the old ones. Above all have only genuine VW parts fitted they aren't expensive and often cheaper than aftermarket. Cambelt replacement is such an important item that personally I would only entrust to a known VW dealer. If something does go wrong you probably have a better chance of a satisfatory conclusion, plus you get a years warranty on the work. Why chance it to save a few quid! If it's the original cambelt and over 4 years old it's already overdue! (No cnnections with VW!) [/ QUOTE ] Yes the engines are the same, but changing a passat belt is a totally different game. The Aux belt is not so important on a golf because it easy to change afterwards. But like they all say get all the tensioner,damper (only upto 2002) and water pump changed Link to comment Share on other sites More sharing options...
Oli Posted January 8, 2007 Report Share Posted January 8, 2007 [ QUOTE ] Reasonable would be somewhere round the £175 - £225 mark for an independent, and add £50 - £80 for a main dealer. Depends on the location in the UK really. Also, make sure they know what they're doing. Certain threads on here from people who didn't know what they were doing leads to problems. ECU remap should make no difference. [/ QUOTE ] I think its a little bit more than that due to the price of the kit and, we always advise a water pump change on these models Link to comment Share on other sites More sharing options...
Tobes49 Posted January 9, 2007 Report Share Posted January 9, 2007 Just checked where I work and it £313.89 upto 2002 and £259.11 for 2002 onwards, This is belt, tensioner, damper(upto 02 only), idler, water pump and new G12 antifreeze. And when I say upto 2002 you need a engine number to be sure which one it is. Link to comment Share on other sites More sharing options...
