terrymcg Posted February 4, 2007 Report Share Posted February 4, 2007 Hi, Can any guru tell me what causes these faults and how to rectify them: VAG-COM Version: Release 607.3-UD Control Module Part Number: 8P0 959 801 H Component and/or Version: Tuer-SG 020 0090 Software Coding: 0000632 Work Shop Code: WSC 06314 1 Fault Found: 00932 - Electric Window Motor; Drivers Side (V147) 005 - No or Incorrect Basic Setting / Adaptation – Intermittent VAG-COM Version: Release 607.3-UD Control Module Part Number: 8P0 959 802 H Component and/or Version: Tuer-SG 020 0090 Software Coding: 0000632 Work Shop Code: WSC 06314 1 Fault Found: 00933 - Electric Window Motor; Passenger Side (V148) 005 - No or Incorrect Basic Setting / Adaptation – Intermittent VAG-COM Version: Release 607.3-UD Control Module Part Number: 1K0 907 530 G Component and/or Version: J533__Gateway H10 0140 Software Coding: 7F0F074007000101 Work Shop Code: WSC 06314 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 240 Mileage: 18549 km Time Indication: 0 Date: 2007.02.04 Time: 16:33:36 VAG-COM Version: Release 607.3-UD Sunday,04,February,2007,16:46:22 Gateway Installation List: 1K0 907 530 G 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Not registered 0001 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 <font color="red"> </font> 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 76-Park Assist -- Status: OK 0000 __________________ Link to comment Share on other sites More sharing options...
PetrolDave Posted February 4, 2007 Report Share Posted February 4, 2007 The last two I've answered your post on www.navplus.us - you need to change the long coding of the CAN gateway to tell it that you have fitted the RNS-E. The first two sound like an intermittent connection. Link to comment Share on other sites More sharing options...
