makonnda Posted October 16, 2003 Report Share Posted October 16, 2003 fitted an pipercross air filter to my mk3 gti - but heard it may be quite bad for the engine is this true? Link to comment Share on other sites More sharing options...
shao_khan Posted October 21, 2003 Report Share Posted October 21, 2003 It can cause some problems - but then again ou could be ok. On some of the later models it can lead to contamination and clogging of the Mass Aiflow meter/sensor which can lead to fueling issues and possible problems with the way the car runs - on my TT it sufered some real flat spots when accelerating - AmD identified problems with teh MAF and when it was changed problems went away. The airfilter can cause problems for this because it can allow more dirt particale to pass into the system and the oiled types can also lead to oil particles passing and sticking to the sensor. Also on certain engines you can actually see a performance drop when fitting certain filters. Link to comment Share on other sites More sharing options...
