chasdrury
Any Arcserve Gurus?
19 posts in this topic
Hi Guys
We have got an Arcserve backup system in place - my PC backups up from 6 client agents on servers.
On one of the servers it backups every night, I get the following errors
E3719
Unable to write to media. (MEDIA=F-HEROUK-MON-05/02/07 [s/N: 1000013], EC=UNRECOVERABLE DATA ERROR)
E8535
Failed to receive data from the client agent. (ADDRESS=172.19.0.200 (RENSHAW008 ( 172.19.0.200 )), EC=10053, COMMAND=80)
E3719
E3712
Unable to close session. (EC=UNRECOVERABLE DATA ERROR)
Now, I am sure its not the media (tried new media last night) and it can't be the drive - all the other servers backup ok..
What can it be!!!
Cheers
Chaz
Used to get similar with BackupExec and it turned out that the Agent installed on one of the client PC's didn't have permission to access a couple of files which caused it to crap out.
Thats what I have been thinking. The client on the server is logged in as Administrator so there shouldn't be any problems there......
Not something silly like Outlook being left open but the administrator account not having permission to access a users Outlook mailbox (think this only applies in the world of Exchange connected Outlook clients though).
Could the files its trying to back up be locked by and app. We've had this before. Exclude them and it sails through no problem.
Can you get it to tell you which files its having trouble with ?
Thats the problem the logs don't tell me how far it got!! How annoying!
I am currently backuping up section by section to try and narrow it down...!
Chaz
Urgh! Arcserve! That was the bane of my life until I tamed it. Unfortunately, I'm still on an old version, so I know one day I'll have to bite the bullet and upgrade it, with all the pain that promises. crazy.gif
What version of Arcserve? What agent exactly? Open File or Regular Win32 agent?
I found that I finally laid a lot of my random crashes to bed by creating a local user called "Arcserve" (for argument's sake) on the Arcserve server, and making it a member of Administrators. I logged on as that user and set up an Outlook profile for email alerting. After installing Arcserve and MSDE, I changed the service accounts to be my Arcserve user and restarted them.
Then I created a domain user account with the same name and password, and added it to the it Domain Administrators group. I logged into all servers as that user to create a local profile on them. I installed the agent to run as that user account.
I created the backup job while logged in as the ASSERVER\Arcserve account. Then in my backup job, when submitting, I set the security for each remote server to DOMAIN\Arcserve and the relevant password.
I've got some unix agents, which behave prefectly, so I knew it was somehow permissions related, and that trick seems to have fixed it. I even frigged the Exchange Agent to work in 'bricks level' against Exchange 2003.
Touch wood, I only get bad backups if an agent dies, for example I know that if I haven't given the DOMAIN\Arcserve user full rights to all Exchange Public Folders, it dies trying to back up any it can see but not read the contents of.
Chaz, are you absolutely sure the media is OK? I've had this error a few times and it's always been either the drive or the media.
Thanks for all the help guys.
Arcserve is pooo but it was here when I arrived! So I have to put up with it. I am pretty sure its not the media, it's different media every night... and its not the drive - I can run backups in the day of files and have no issues...
Its very weird.. I have had 'Dylan' from arcserve support in India looking at it and he reckons the firmware is too high on the tape drive...
Its not permissions - if I backup the server in question part by part it seems to be fine and backups everything it should do!
Chaz
Sounds a bloody wierd one chaz. I'm afraid I'm no where near technical enough to be able to help frown.gif , so I'll stick with the useless flippant comments. tongue.gif
Chaz, are any of these machines that are causing problems, an FTP/Webserver?
No Sparky...
Just plain old machines. One is a Notes (yuk) server but that backups fine...
Chaz
Just standard files then? Doc/xls/ppt/mp3 sort of files?
No chance the program that uses them is still in memory?
Yeah, just fairly standard files. It has the open file assistant on all the servers too....
There's a patch that addresses this. Have a look at QO52534 on CA's site.
Also, make sure the Agent is the same version as the Server. There's a timeout value somewhere in the registry too. It may be that Arcserve is waiting too long for the data. Have you run a chkdsk against the drives in question?
Thanks nordberg, will try that
Last night before I left I downgraded the firmware of the tape drive and it worked.... Slowly, but it worked...
The firmware hasn't been updated for months though, so why would it just suddenly stop working?!
Chaz
