sidicks
Audi R8 - Sat Nav question
11 posts in this topic
Just a quick question about the opional Sat Nav system in the R8 - Does this include a TV tuner, as is available for other models in the range?
If not, why not? Can it be retro-fitted?
Cheers
Sidicks
Sat nav in the R8 is the standard RNS-E as used in the A3/A4/TT. So it would not be included, but I don't see any reason why Audi would not include it as an option. And if it is an option, then it can be retrofitted.
But my advice would be if it can be factory fitted then order your R8 with it. Retrofitting TV is not cheap as it is quite a labour intensive.
As craigyb says, fitting the TV option is much more than just fitting a TV tuner.
On the A4 it also means adding the fitting tray for the tuner in the boot, new aerial amplifers both sides and quite a lot of wiring from front to back of the car and around the boot area.
Might be "interesting" trying to do that working around the mid engine on the R8.
So why have the used the Sa Nav from the A3/A4/TT range, rather than the (presumably) superior unit from the A6 / A8 range?
It seems slightly strange as the R8 is meant to be the new flagship vehicle..................
Sidicks
Does the Gallardo not have a TV option? I thought they were based on the same hardware?
Sidicks
Gallardo is RNS-E as well and it can have TV as an option
Surprised that is's not available on the R8 in that case!
Sidicks
Not the most worthwhile option though really...
Obviously not, but if you have the Sat Nav already then it shouldn't (in theory) cost much extra, and could be useful on the odd occasion.
Sidicks
Unless you live in Cumbria - which is the first region to have analogue TV switched off later this year.
