NicNic Posted March 26, 2007 Report Share Posted March 26, 2007 I have just sheered off one of the 3 rocker cover fastners on my 1.9TDI MK3 Golf (far left fastner). Whats peoples views on being able to drive my car to a garage or sould i not be running the engine with above damage and have it towed etc?!?!? Thanks Link to comment Share on other sites More sharing options...
Mook Posted March 27, 2007 Report Share Posted March 27, 2007 Welcome to Tyresmoke Are you talking about the plastic cover over the rocker cover, or the actual rocker cover. IIRC, there's more than three nuts securing the rocker cover onto the head? Link to comment Share on other sites More sharing options...
NicNic Posted March 27, 2007 Author Report Share Posted March 27, 2007 There are 3 threds that attach to the engine block holding the rocker cover in place. I just replaced the gasket so the rocker cover was removed, cleaned and replaced. Tightened one a little too much though. Thanks Link to comment Share on other sites More sharing options...
Mook Posted March 27, 2007 Report Share Posted March 27, 2007 You'll be fine to drive it for a short distance, but you'll probably get oil seeping from the cover. The existing bolt will need to be removed and the thread in the cylinder head re-tapped with an oversize bolt. Pain in the a*se to do, but that's about your only option. Link to comment Share on other sites More sharing options...
NicNic Posted March 29, 2007 Author Report Share Posted March 29, 2007 Many Thanks. Due for a cam belt change so ill book her in for that and to fix the rocker cover. Link to comment Share on other sites More sharing options...
