Atomic Posted May 28, 2007 Report Share Posted May 28, 2007 Looking at some of the older TT's - around 1999/2000 and would like some advice in terms of wear and tear and common faults. Not so much battle damage, I'll make sure the car is inspected if need be but more then running gear, engine, interior, dodgy painwork etc. Thanks, AG> Link to comment Share on other sites More sharing options...
ChadW Posted May 28, 2007 Report Share Posted May 28, 2007 Ensure the cambelt has been changed at least once as it should be done every 60k or 5 years. Check that the wheel bearing recall has been done too as this was need for early 99 models. Usual TT probs. are dashpod failure (can be repaired for free if the dealer is nice), MAF and Coil failure which can be seen if the engine is runing rough or lumpy when idle. Diverter Valve split means a high whistle when go up the gears and loss of performance and finally clutch slip which could mean new flywheel and or master cylinder going. These are probs. which are not going to break the bank but the cambelt change can cost a lot more. Mine needs doing really as my car is 2001 with 68k and no cambelt change was done on it. Then again the car is under a 2 year warranty and the dealer assumes it needs to be done at 80k, so in that respect I should be ok if it did go. Link to comment Share on other sites More sharing options...
kite Posted May 29, 2007 Report Share Posted May 29, 2007 As said above, also clutch pedal failure, drivers seat bolster is a common wear problem. The roof rails are known to flake the paint but these are covered by the paint warranty, if you have a nice dealer ! Link to comment Share on other sites More sharing options...
Atomic Posted May 29, 2007 Author Report Share Posted May 29, 2007 What model to go for? the 180 or 225? And anything extra to worry about with the roadster? Thanks for you help btw. Link to comment Share on other sites More sharing options...
kite Posted May 29, 2007 Report Share Posted May 29, 2007 225, we have the coupe Link to comment Share on other sites More sharing options...
ChadW Posted May 29, 2007 Report Share Posted May 29, 2007 Yeah 225 Coupe is the way to go, Roadster is heavier so slower but fun in the summertime I guess. Link to comment Share on other sites More sharing options...
shao_khan Posted May 29, 2007 Report Share Posted May 29, 2007 Roadster is the choice try to make sure you find a roadster with Bose - it makes a big differnce with the roof down. Link to comment Share on other sites More sharing options...
Atomic Posted May 29, 2007 Author Report Share Posted May 29, 2007 And colour for a roadster? My preference at the moment is black Link to comment Share on other sites More sharing options...
shao_khan Posted May 29, 2007 Report Share Posted May 29, 2007 The cheapest TTr you are likely to find will probably be the same combo that my first one was: http://www.woofdoggy.com/Audi_TT.htm Nimbus with Baseball. The best colour though is definately this one: http://www.woofdoggy.com/audi_tt_berry.htm I do think that Black with Baseball looks cool with the roof down as its a nice contrast and then with roof up its all one colour As for engine - I'd go for either 225 as you can get a reliable 260 - 270 bhp from these engines should you ever feel the need for more or the 150 fwd as these have far more boot space than the 225 or 180. Link to comment Share on other sites More sharing options...
Atomic Posted May 29, 2007 Author Report Share Posted May 29, 2007 Well I'll be in sunny Aus so all bets are off in terms of colour/price I'm also guessing that a TTR wont be on the cards as well. I'm surprised you mention the 150... I was tempted earlier but thought i'd get flamed Link to comment Share on other sites More sharing options...
lottiefox Posted May 29, 2007 Report Share Posted May 29, 2007 Cambelt as said, water pump, check servicing has been regular Tyres - check wear patterns - many TTs seem to suffer from uneven running/bad alignment Boost - does it come on boost properly and are there any odd noises/smoking signs from anywhere? ARBs - they can clonk when going over bumps - relatively easy to fix and may be the bushes wearing Look for BOSE if possible - better system and good for resale Make sure no flat spots on acceleration or lumpy moments - could indicate coils/MAF Check the dash pod as mentioned - does it give accurate readings on things? Check if imported car at all, may affect warranty on things like the dash pod. Enjoy!! Link to comment Share on other sites More sharing options...
shao_khan Posted May 29, 2007 Report Share Posted May 29, 2007 [ QUOTE ] I'm surprised you mention the 150... I was tempted earlier but thought i'd get flamed [/ QUOTE ] The 150 is great, it isnt as fast, but it still looks the part, plus it has a boot you can get shed loads into, My mrs had one after our daughter was born - she could get buggy, plus baby rubbish into the boot with ease Also 2wd means less transmission loss so it doesnt feel that slow. Link to comment Share on other sites More sharing options...
Atomic Posted May 30, 2007 Author Report Share Posted May 30, 2007 Wonder if they have the 150's in Aus. Does anyone have any piccies of the normal and 150 boot? Link to comment Share on other sites More sharing options...
ChadW Posted May 30, 2007 Report Share Posted May 30, 2007 Imagine it would look the same as any normal roadster just the difference is about 4 inches or so deeper on the 150 due to no quattro mechanics present. Link to comment Share on other sites More sharing options...
shao_khan Posted May 31, 2007 Report Share Posted May 31, 2007 The difference is getting a childs buggy in the boot and not I never took pics of the boot of either of mine. Link to comment Share on other sites More sharing options...
shark_90 Posted May 31, 2007 Report Share Posted May 31, 2007 [ QUOTE ] [ QUOTE ] I'm surprised you mention the 150... I was tempted earlier but thought i'd get flamed [/ QUOTE ] The 150 is great, it isnt as fast, but it still looks the part, plus it has a boot you can get shed loads into, My mrs had one after our daughter was born - she could get buggy, plus baby rubbish into the boot with ease Also 2wd means less transmission loss so it doesnt feel that slow. [/ QUOTE ] I have a 150 Golf with a Revo remap and it's very quick. Quicker than my ~230bhp quattro A4 certainly. If you're not bothered about not having quattro I'd wager that a remapped 150 would be (noticeably) quicker than a standard 225. Link to comment Share on other sites More sharing options...
ChadW Posted May 31, 2007 Report Share Posted May 31, 2007 LOL hope you are talking about the 225 Roadster here, as not sure you'd be quicker than a 225 coupe. Link to comment Share on other sites More sharing options...
shao_khan Posted May 31, 2007 Report Share Posted May 31, 2007 easy - i bet if you work out power at the wheels, the chipped 150 will be equal to or have more than the 225 due to the tranmission loss. Link to comment Share on other sites More sharing options...
ChadW Posted May 31, 2007 Report Share Posted May 31, 2007 Bet it won't beat a remapped 225 then! Link to comment Share on other sites More sharing options...
shao_khan Posted May 31, 2007 Report Share Posted May 31, 2007 not mine it wouldnt Link to comment Share on other sites More sharing options...
ian_m Posted June 4, 2007 Report Share Posted June 4, 2007 You would also have to factor the cost of a new set of wheels into a 150 though - it comes with 16" wheels Some did come with 17"s, but IMO 18"s are much better on a TT Link to comment Share on other sites More sharing options...
