Oli18 Posted June 3, 2007 Report Share Posted June 3, 2007 Hi guys, Bought a non ross-tech cable from http://www.talktomycar.co.uk/Shop/OBD2_Interfaces/mj020.htm Not ideal, i know, but it's a lot of money for the real deal. Have installed the drivers and VAG COM and can't get the thing to confirm a test. COM1 comes back saying the port is working but the device is not found. When i try COM2, 3 or 4 is says they 'do not exist' and USB comes back saying that 'no ross-tech cable was found'. I have tried uninstalling, reinstalling and installing various different drivers but no luck. My device manager comes back with this (see below) which seems to indicate that the device is installed ok. The cable itself has an active green light when plugged into the car. I think i'm booting it up ok in that i plug in the cable 1st, start the car (or just turn electrics on) and then start VAG COM. I have tried other sequesnces but no luck as yet. My device manager says it's on COM24...VAG COM only has COM1,2,3,4 and USB. Could this be the issue? Any insight greatly appriciated Many thanks, Oli Link to comment Share on other sites More sharing options...
Markpaq Posted June 3, 2007 Report Share Posted June 3, 2007 Can't you just right click on the USB Serial device and tell it to use COM2? Link to comment Share on other sites More sharing options...
PsYcHe Posted June 3, 2007 Report Share Posted June 3, 2007 That will be the problem .. There are procedures out there for forcing the com port on a device.. Google away.. I remember having this problem with bluetooth serial ports for syncing my phone. Link to comment Share on other sites More sharing options...
Oli18 Posted June 3, 2007 Author Report Share Posted June 3, 2007 Thanks guys, i found out that when you right click the device (in device manager), go to properties, then to the 'port settings' tab and then click 'advanced' you can change the com port. It works now! Thanks for the help. -Oli Link to comment Share on other sites More sharing options...
Ady_E Posted June 13, 2007 Report Share Posted June 13, 2007 Yeah I had to do the same thing. Only trouble was VAG-COM kept saying all ports 1 to 4 didn't exist! Link to comment Share on other sites More sharing options...
