Oli18 Posted June 4, 2007 Report Share Posted June 4, 2007 Just a quick question but i have just gotten the ebay dongle to work with the freeware and some errors came back (see below). Am i right in assuming that it's wise to clear the codes and then re-check in a week's time to see if they come back? Also, does clearing the fault code stop the error from popping up on my dashboard after the 'check' function has been pressed as mine still shows some errors (eventhough i cleared the errors in VAG-COM)... See vid of errors here: http://uk.video.yahoo.com/video/play?vid=614862 Many thanks, Oli PS- what is a DTC? and are the non-bolded items below actual errors? Engine 16502 - Engine Coolant Temp. Sensor (G62): Signal too High 17977 - Shareware Version. To Decode all DTCs P1569 - 35-10 - Please Register/Activate - Intermittent 18011 - Shareware Version. To Decode all DTCs P1603 - 35-10 - Please Register/Activate – Intermittent Airbag 00532 - Supply Voltage B+ (airbag) Instruments 00668 - Supply Voltage Terminal 30 53-10 - Supply Voltage Too Low - Intermittent 00562 - Shareware Version. To Decode all DTCs 30-10 - Please Register/Activate - Intermittent 00562 - Shareware Version. To Decode all DTCs 29-10 - Please Register/Activate – Intermittent Centrt. Elect. 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01372 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01368 - Shareware Version. To Decode all DTCs 35-00 - Please Register/Activate 01366 - Opened Due to Crash Signal 35-00 - - 00991 - Shareware Version. To Decode all DTCs 28-00 - Please Register/Activate 00956 - Shareware Version. To Decode all DTCs 09-00 - Please Register/Activate 01134 - Alarm Horn (H12) 77-00 - Internal Supply Voltage Radio: 00856 - Radio Antenna Park Assist: 01546 - Sensor for Parking Aid: Rear Mid-Left (G204) 01626 - Shareware Version. To Decode all DTCs 30-00 - Please Register/Activate 01627 - Shareware Version. To Decode all DTCs 30-00 - Please Register/Activate 01628 - Sensor for Parking-Aid: Front Mid-Left (G254) 37-10 - Faulty - Intermittent 01629 - Shareware Version. To Decode all DTCs 31-00 - Please Register/Activate Link to comment Share on other sites More sharing options...
PetrolDave Posted June 4, 2007 Report Share Posted June 4, 2007 [ QUOTE ] Just a quick question but i have just gotten the ebay dongle to work with the freeware and some errors came back (see below). Am i right in assuming that it's wise to clear the codes and then re-check in a week's time to see if they come back? [/ QUOTE ] Worth clearing them, and re-checking almost immediately & maybe again a week later. That will tell you if they are old stored codes from an intermittent event or current codes. Of course with registered VAG-COM it stores the date & time too as well as decoding the DTC's. Link to comment Share on other sites More sharing options...
Oli18 Posted June 4, 2007 Author Report Share Posted June 4, 2007 Thanks PetrolDave! I am considering buying the license! A few more questions I was hoping that someone might know the answer to... 1. What are DTCs exactly? 2. Does anyone have any feedback on the errors that come up on the dash (see video link http://uk.video.yahoo.com/video/play?vid=614862)? Would like to get rid of them if i can. It's strange that i.e. the washer fluid light comes on and petrol as they're both plenty full... 3. Are Non-bolded errors in 1st post above actually errors? My guess is that they are errors but because i have the shareware version, i can not see what they are...is this correct? Cheers! -Oli Link to comment Share on other sites More sharing options...
Sebastian Posted June 4, 2007 Report Share Posted June 4, 2007 [ QUOTE ] 1. What are DTCs exactly? [/ QUOTE ] Diagnostic trouble codes. [ QUOTE ] 2. Does anyone have any feedback on the errors that come up on the dash... [/ QUOTE ] They are the visual confirmation of the fault codes stored. [ QUOTE ] 3. Are Non-bolded errors in 1st post above actually errors? My guess is that they are errors but because i have the shareware version, i can not see what they are...is this correct? [/ QUOTE ] Correct. http://www.ross-tech.com/Merchant2/merch...ory_Code=VAGCOM P.S.: Some of the codes may be covered by our WIKI, another thing we came up with to help our customers... http://wiki.ross-tech.com/index.php/Category:Fault_Codes Link to comment Share on other sites More sharing options...
Ady_E Posted June 13, 2007 Report Share Posted June 13, 2007 [ QUOTE ] Thanks PetrolDave! I am considering buying the license! [/ QUOTE ] I Think the Licence is expensive. You can download the crack. Link to comment Share on other sites More sharing options...
UweRoss Posted June 13, 2007 Report Share Posted June 13, 2007 [ QUOTE ] I Think the Licence is expensive. [/ QUOTE ] Let's put some perspective on the price of the license: * How many times can you fill the fuel tank on an A8 for $99 USD? * How much does your dealer charge you for one hour of diagnostic time (which is typically the minimum they will charge)? * How much does the factory tool cost? [ QUOTE ] You can download the crack. [/ QUOTE ] Click here for a crack... -Uwe- Link to comment Share on other sites More sharing options...
TDiAvant Posted June 13, 2007 Report Share Posted June 13, 2007 [ QUOTE ] I Think the Licence is expensive. You can download the crack. [/ QUOTE ] I think the license is very cheap, and the amount of times VAG-COM has helped me out has saved me ££££. Stop being a **** and buy the license. Link to comment Share on other sites More sharing options...
techieboy Posted June 13, 2007 Report Share Posted June 13, 2007 [ QUOTE ] Click here for a crack... -Uwe- [/ QUOTE ] Good on you, Uwe! Link to comment Share on other sites More sharing options...
Ady_E Posted June 13, 2007 Report Share Posted June 13, 2007 [ QUOTE ] How many times can you fill the fuel tank on an A8 for $99 USD? [/ QUOTE ] It depends? In the UK you can just about fill it 3/4 full. In the US you can fill it several times! Since, living in the UK, I have to spend more of my hard earned cash on fuel, I'll use the crack and put the cash saved in the tank! Thanks. Link to comment Share on other sites More sharing options...
davidhodgkinson Posted June 13, 2007 Report Share Posted June 13, 2007 [ QUOTE ] [ QUOTE ] How many times can you fill the fuel tank on an A8 for $99 USD? [/ QUOTE ] It depends? In the UK you can just about fill it 3/4 full. In the US you can fill it several times! Since, living in the UK, I have to spend more of my hard earned cash on fuel, I'll use the crack and put the cash saved in the tank! Thanks. [/ QUOTE ] Believe me.... It's worth the outlay, just pay up!!! Link to comment Share on other sites More sharing options...
TDiAvant Posted June 13, 2007 Report Share Posted June 13, 2007 You may as well talk to a brick wall.... Link to comment Share on other sites More sharing options...
PetrolDave Posted June 14, 2007 Report Share Posted June 14, 2007 [ QUOTE ] Since, living in the UK, I have to spend more of my hard earned cash on fuel, I'll use the crack and put the cash saved in the tank! Thanks. [/ QUOTE ] I live in the UK and run an RS4 - so I KNOW about the cost of petrol!!! But I still bought the proper licence. Why? The support I've had from Uwe and colleagues has been tremendous, all questions answered quickly and accurately. You won't get that by using the cheap crack... Link to comment Share on other sites More sharing options...
timps Posted June 14, 2007 Report Share Posted June 14, 2007 [ QUOTE ] Since, living in the UK, I have to spend more of my hard earned cash on fuel, I'll use the crack and put the cash saved in the tank! Thanks. [/ QUOTE ] Here is an idea to save even more money, why not drive off without paying for the petrol as well. When a company takes the trouble to answer questions about their product on a forum for free then they get a lot of respect. Edited to add: I bought the licence as well. Link to comment Share on other sites More sharing options...
Ady_E Posted June 14, 2007 Report Share Posted June 14, 2007 [ QUOTE ] How many times can you fill the fuel tank on an A8 for $99 USD? It depends? In the UK you can just about fill it 3/4 full. In the US you can fill it several times! Since, living in the UK, I have to spend more of my hard earned cash on fuel, I'll use the crack and put the cash saved in the tank! Thanks. [/ QUOTE ] OK. The above was a bit of 'misplaced' joviality on my part. Wrong audience I guess. I humbly apologise to any member of Tyresmoke.net and the Ross-Tech organisation that may be offended by any of the comments I have made relating to Ross-Tech products or the cost of the Software License. When I’d successfully completed testing my interface it became apparent that I now needed to activate/register the software. When visiting the Ross-Tech website to find out how I go about this, I was inundated by long forms for this and short forms for that and the site didn’t appear forthcoming with the price of a license which, in my experience, is usual a bad sign. My remark below was based on my findings which are completely unfounded and I again apologise. [ QUOTE ] I Think the Licence is expensive. You can download the crack. [/ QUOTE ] This evening though I found that information straight away. I couldn’t find it for looking the other day! I was genuinely quite surprised when Uwe said it was only 99 USD and you’re absolutely right, I would cost more than that to have Audi read fault codes once. Needless to say, I will be registering my copy if I decide to continue using it. If I decide not to, rest assured I will uninstall it, full stop. I fully accept the kick in the ‘crack’ I have been given. Link to comment Share on other sites More sharing options...
techieboy Posted June 14, 2007 Report Share Posted June 14, 2007 Nice one Ady, it is bloody useful Link to comment Share on other sites More sharing options...
