brownswood
stereo removal keys needed - south west
9 posts in this topic
hi anyone have a set handy i can borrow in a quick meet sometime over the next cpl days or even tomorrow if possible. i have a new 07 style cd unit arriving tomorrow and want to swap it with the 06 one i currently have...
does anyone know if the new unit will need VAG coding in at all?
thanks
John Carter has one key - I used a metal nail file as the other one!! 169144-ok.gif
Yep I have one - the other one is somewhere in my house/garage/car/etc. etc. ROLLEY~14.GIF
Depends what you mean by "CD unit".
If it's the CD changer (doubtful since the 07 and 07 ones are identical) then no.
If it's an 07 Symphony II+ to replace an 06 Symphony II then it's coding will need checking - and it won't fit! Physically it will, but the connectors are different.
Need more information to answer your question ...
Did you buy that concert II+ unit, well this is where the fun begins.
The Symphony II unit you have uses diversity and HF connections and old ISO connectors. The new concert II+ is dual HF and no diversity, also the connectors are quad lock.
You will need "special" adaptors to make this work.
Craig,
Since I replaced my Concert II+ with the RNS-E I get the following error.
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Is that related to your comments above? Can it be resolved? It all works ok it's just annoying to see the error in Vag-Com all the time.
TIA.
Sounds expensive.
I think I'll make do with it the way it is.
Cheers.
