brownswood Posted July 18, 2007 Report Share Posted July 18, 2007 hi anyone have a set handy i can borrow in a quick meet sometime over the next cpl days or even tomorrow if possible. i have a new 07 style cd unit arriving tomorrow and want to swap it with the 06 one i currently have... does anyone know if the new unit will need VAG coding in at all? thanks Link to comment Share on other sites More sharing options...
ian_m Posted July 19, 2007 Report Share Posted July 19, 2007 John Carter has one key - I used a metal nail file as the other one!! Link to comment Share on other sites More sharing options...
J_C Posted July 19, 2007 Report Share Posted July 19, 2007 Yep I have one - the other one is somewhere in my house/garage/car/etc. etc. PM me if you want to sort something out. Link to comment Share on other sites More sharing options...
PetrolDave Posted July 19, 2007 Report Share Posted July 19, 2007 [ QUOTE ] 07 style cd unit arriving tomorrow and want to swap it with the 06 one i currently have... does anyone know if the new unit will need VAG coding in at all? [/ QUOTE ] Depends what you mean by "CD unit". If it's the CD changer (doubtful since the 07 and 07 ones are identical) then no. If it's an 07 Symphony II+ to replace an 06 Symphony II then it's coding will need checking - and it won't fit! Physically it will, but the connectors are different. Need more information to answer your question ... Link to comment Share on other sites More sharing options...
TDiAvant Posted July 19, 2007 Report Share Posted July 19, 2007 You will also need 4 keys to remove a Symphony unit. Link to comment Share on other sites More sharing options...
craigyb Posted July 20, 2007 Report Share Posted July 20, 2007 Did you buy that concert II+ unit, well this is where the fun begins. The Symphony II unit you have uses diversity and HF connections and old ISO connectors. The new concert II+ is dual HF and no diversity, also the connectors are quad lock. You will need "special" adaptors to make this work. Link to comment Share on other sites More sharing options...
Markpaq Posted July 20, 2007 Report Share Posted July 20, 2007 Craig, Since I replaced my Concert II+ with the RNS-E I get the following error. 1 Fault Found: 00858 - Connection; Radio ZF Output to Antenna Amplifier 007 - Short to Ground Is that related to your comments above? Can it be resolved? It all works ok it's just annoying to see the error in Vag-Com all the time. TIA. Link to comment Share on other sites More sharing options...
craigyb Posted July 20, 2007 Report Share Posted July 20, 2007 Yes, it can be resolved with a new antenna system Link to comment Share on other sites More sharing options...
Markpaq Posted July 20, 2007 Report Share Posted July 20, 2007 Sounds expensive. I think I'll make do with it the way it is. Cheers. Link to comment Share on other sites More sharing options...
