andysimpson Posted July 24, 2007 Report Share Posted July 24, 2007 Hello all, I am trying to change the ignition switch on my Polo gti 2000 but i am having great difficuilty getting the steering wheel off as i cannot remove the air bag. there are 2 holes underneath but there are no bolts inside just springs??? can anyone help??? Link to comment Share on other sites More sharing options...
Gezza88 Posted November 29, 2009 Report Share Posted November 29, 2009 Hi I have just replaced Ignition barrel lock on my Polo. Not sure if the steering wheel is the same but here is what I did. Underneath the wheel there are two "holes". These are for allen keys - undo these 2 anld lift off centre of steering wheel - be careful there is flat strap wire which has a connector to the airgbag. Once you get this off you can remove wiper and indicator assemblies. Then you need a 22 or 24mm socket to remove the steering wheel. Hope this helps. Gerry Link to comment Share on other sites More sharing options...
