asfastaspossible Posted August 5, 2007 Report Share Posted August 5, 2007 Sat Nav retrofit . Guys any idea if its possible to retrofit Sat Nav to the I Drive on my BMW530D SE ( 2005) Link to comment Share on other sites More sharing options...
Alastair_A3 Posted August 5, 2007 Report Share Posted August 5, 2007 Im guessing it would be quite hard because the sat nav screen is quite abit bigger than the normal idrive screen. You'd prob need a new section of dash.. bet thats cheap Link to comment Share on other sites More sharing options...
gizze Posted August 5, 2007 Report Share Posted August 5, 2007 You can retrofit either the business nav using your existing screen or the professional nav but you need to buy the bigger 8" screen. You are best to source the parts from www.ebay.de it is far, far cheaper, then get your dealer to programme it. http://www.realoem.com/bmw/showparts.do?...hg=65&fg=95 http://www.realoem.com/bmw/showparts.do?...hg=65&fg=95 And here are the bits you need for under £600 http://cgi.ebay.de/BMW-E60-E61-DVD-Navi-...VQQcmdZViewItem You may need a new i-drive controller, get bmw to check this for you, if you do it is around £160 from the dealer. Link to comment Share on other sites More sharing options...
asfastaspossible Posted August 8, 2007 Author Report Share Posted August 8, 2007 Thanks, Looks like Total cost around £800 plus fitting Regards Link to comment Share on other sites More sharing options...
