RedRobin Posted August 23, 2007 Report Share Posted August 23, 2007 [ QUOTE ] Not far off a post every 2 miles then RR [/ QUOTE ] .... How many posts-per-gallon does that compute to then? About 14 ppg I reckon But on the subject of learning DSG I would suggest a newbie simply relaxes and gets used to each mode one by one before combining the options on offer. Some of us only use D, some only D and S, some just M plus paddles, others M plus floorstick, and others a combination according to conditions and mood. It's also easy to switch from one to another set of options. Can't go directly from M to S though, unfortunately, but you can even override D or S modes for 30 seconds. Don't let anyone convince you it's like a Playstation - Believe me, DSG can be just as involving as a conventional Manual. The GTI isn't a rally car but why do rally cars have paddle shifts? It might have a more expensive clutch system but I reckon that clutch wear is greatly reduced (and gear shifts are fast and faultless every time - Well, 99.9%). DSG is worth the extra in my opinion. Link to comment Share on other sites More sharing options...
ekin_88 Posted August 23, 2007 Author Report Share Posted August 23, 2007 Thanks Red for your input and snoopy I will do a search on the forum for the post. I am looking forward to the experience, I will leave it in D for the first 1000 miles and then experiment, RR do you need to stop the car to swap it from M to S or do you push stick to D then Drop to S on the move? I might sound daft but its worth to ask the question. Link to comment Share on other sites More sharing options...
JonnyGTi Posted August 23, 2007 Report Share Posted August 23, 2007 [ QUOTE ] do you need to stop the car to swap it from M to S or do you push stick to D then Drop to S on the move? [/ QUOTE ] You guessed it - while on the move you just shift the stick to the side (from M to D) and then down a slot from (D to S). Can't say I really ever need to do that change much though Link to comment Share on other sites More sharing options...
mikemod Posted August 24, 2007 Report Share Posted August 24, 2007 I find when I'm in 6th and I am in manual if I switch to "S" and then back to manual before overtaking it usually knocks you down to 3rd instantly. Saves you having to hit the paddle three times Link to comment Share on other sites More sharing options...
stooH Posted August 24, 2007 Report Share Posted August 24, 2007 I just use the stamp down or whatever it's called and it does the same job at exactly the same time that you start accelerating, the trick of course is to time it so all that happens and allows the boost to build back up so you can move over quickly and easily. Link to comment Share on other sites More sharing options...
ekin_88 Posted August 25, 2007 Author Report Share Posted August 25, 2007 [ QUOTE ] [ QUOTE ] do you need to stop the car to swap it from M to S or do you push stick to D then Drop to S on the move? [/ QUOTE ] You guessed it - while on the move you just shift the stick to the side (from M to D) and then down a slot from (D to S). Can't say I really ever need to do that change much though [/ QUOTE ] this is going to take a lot of learning, but cheers for info, i cant wait for my GTI Link to comment Share on other sites More sharing options...
RedRobin Posted August 25, 2007 Report Share Posted August 25, 2007 ....No, it'll take less learning than you imagine. It'll just take time to become naturally fluid so you don't even think about it anymore. Just keep it simple and try one option at a time to start with - The DSG box of tricks is your friend . Link to comment Share on other sites More sharing options...
ekin_88 Posted August 26, 2007 Author Report Share Posted August 26, 2007 [ QUOTE ] ....No, it'll take less learning than you imagine. It'll just take time to become naturally fluid so you don't even think about it anymore. Just keep it simple and try one option at a time to start with - The DSG box of tricks is your friend . [/ QUOTE ] cheers Red for your words and advice, I cant wait till the car arrives but its still going to be a very very long wait. I have tried to search for your post with the DSG write up but can not find them, could you possible post the link for me to read. thanks you very much. Link to comment Share on other sites More sharing options...
JonnyGTi Posted August 26, 2007 Report Share Posted August 26, 2007 There is FAQ here (from another site) :- DSG FAQ Some of the threads I remember on here about DSG are over a year old now and the ones I've found are here :- http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/1101777/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/1069185/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/902524/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/897393/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/889575/page/0/fpart/all/vc/1 From a personal perspective I think the DSG is perfect for the GTI's "torquey" engine and I love the flexibility that the DSG offers. Depending on the mood you're in and the roads you're driving on you have the option of so many driving styles. One of my favourites must be manual mode and using the paddles on twisty 40-70mph country roads . Unfortunately I work in a city and my daily commute is stop / start in queues - but that's when Drive mode comes into it's own Happy reading : Link to comment Share on other sites More sharing options...
ekin_88 Posted August 26, 2007 Author Report Share Posted August 26, 2007 [ QUOTE ] There is FAQ here (from another site) :- DSG FAQ Some of the threads I remember on here about DSG are over a year old now and the ones I've found are here :- http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/1101777/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/1069185/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/902524/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/897393/page/0/fpart/all/vc/1 http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/889575/page/0/fpart/all/vc/1 From a personal perspective I think the DSG is perfect for the GTI's "torquey" engine and I love the flexibility that the DSG offers. Depending on the mood you're in and the roads you're driving on you have the option of so many driving styles. One of my favourites must be manual mode and using the paddles on twisty 40-70mph country roads . Unfortunately I work in a city and my daily commute is stop / start in queues - but that's when Drive mode comes into it's own Happy reading : [/ QUOTE ] Hi JonnyGTi thank you very much for the links and the faq, I will be reading for a while, at least I will be prepared for the day my car arrives, Thank you very much. Link to comment Share on other sites More sharing options...
