mb Posted September 18, 2007 Report Share Posted September 18, 2007 Has Anyone bought/used these & what were they like ? Been wondering as seem to be folding the seats down more & more with the new house ! Link to comment Share on other sites More sharing options...
jimmyp Posted September 18, 2007 Report Share Posted September 18, 2007 What you got in mind Martin, you planning on putting the new house on roof Link to comment Share on other sites More sharing options...
mb Posted September 18, 2007 Author Report Share Posted September 18, 2007 Hi Mate, not quite - you know how much the houses in Poole weigh ! No was thinking of some timberrrrrr as getting a bit bored of measuring & cutting it up in the B&Qs car park - they won't cut if for me either as its treated I seem to need (or is that treatment ?) Link to comment Share on other sites More sharing options...
Mook Posted September 18, 2007 Report Share Posted September 18, 2007 Had these on 3 door and 5 door Golfs. Never fitted them on the R32 because I sold them before I got the car Your best bet is to get some OEM ones - they're not cheap (about £100 IIRC), but they fit better than anything else. Depending on whether yours is a 3 door or 5 door, the 3 door ones clamp onto the roof just above the rear window. If you look carefully enough at the top blacked out line n your rear window, you'll see a small arrow - that's where the rear bar goes. The front ones clamp onto the join which the rubber strip covers over, that you can get access to when you open the front door. Link to comment Share on other sites More sharing options...
mb Posted September 19, 2007 Author Report Share Posted September 19, 2007 Thanks for the info - it is a 3 door car, did they work well, were they easy to put on/take off or do they need to stay on all the time really ? Link to comment Share on other sites More sharing options...
shark_90 Posted September 19, 2007 Report Share Posted September 19, 2007 Not fitted them to a Golf, but it's good if you can remove them fairly easily as they don't do much for your MPG! Link to comment Share on other sites More sharing options...
Dan32 Posted September 19, 2007 Report Share Posted September 19, 2007 Relatively quick to put these on. Had some on the MKIII. Downside is, the span between them isn't very wide so you won't be able to put anything very long on them. I managed a couple of sheets of 8'x6' MDF and couldn't go over 35mph as they were flapping about all over the place! If its decking board you're transporting (treated - pressure treated to resist water ingress and once cut, should be re-treated on the cut surface with a preserver) then maybe better to find a timber merchant who is cheaper than B&Q and can deliver. Link to comment Share on other sites More sharing options...
mb Posted September 19, 2007 Author Report Share Posted September 19, 2007 It was a bit of decking the other day & now need a few bits of wood to make a frame for the bath panel from (was going to use treated for this but guess don't have to) & eventually the bath panel (which will be MDF or something so hopefully they will cut this for me !) I never seem to need enough wood to justify a delivery but carpark construction is getting a bit boring too ! Good point about the span as I have some ladders I would like to move. Link to comment Share on other sites More sharing options...
mattcony Posted September 19, 2007 Report Share Posted September 19, 2007 Will find some pictures here http://www.tyresmoke.net/ubbthreads/show...true#Post805775 cheers Matt Link to comment Share on other sites More sharing options...
mb Posted September 19, 2007 Author Report Share Posted September 19, 2007 Thanks Matt, Looks like the VW ones it is ! Link to comment Share on other sites More sharing options...
mb Posted September 24, 2007 Author Report Share Posted September 24, 2007 Well, got what passes for a bargain at Breeze & some ex-display ones for 65. They cleaned up OK only thing is they are missing the torque key so will have to hand tighten - how tight do you guys do them up (& don't say 6 NM) ? Thanks Link to comment Share on other sites More sharing options...
Mook Posted September 24, 2007 Report Share Posted September 24, 2007 The original Golf ones came with the allen key with the torque "guage" on it. I never checked what the torque actually was, because IIRC, it's not indicated on the car. I reckon you'll know when you've got it tight enough Link to comment Share on other sites More sharing options...
mb Posted September 24, 2007 Author Report Share Posted September 24, 2007 Thanks - I am quite used to tightning things up etc. the destructions say 6 NM - just had visions of caving the roof in when I did them up - were they not very tight, "normal" for an 8mm bolt or did you swing on them ? Link to comment Share on other sites More sharing options...
Mook Posted September 25, 2007 Report Share Posted September 25, 2007 Sorry, I'm not a swinger Link to comment Share on other sites More sharing options...
mb Posted September 25, 2007 Author Report Share Posted September 25, 2007 Nor a Jungle VIP ? Link to comment Share on other sites More sharing options...
Mook Posted September 25, 2007 Report Share Posted September 25, 2007 No. And there's no bloody pampus grass outside my house either Link to comment Share on other sites More sharing options...
mb Posted September 25, 2007 Author Report Share Posted September 25, 2007 I did say I wanted to carry wood back from B&Q not Pampus grass on my roof bars... Link to comment Share on other sites More sharing options...
Mook Posted September 25, 2007 Report Share Posted September 25, 2007 Is that so you can build a new shed for all your swinging friends to camp in...? Link to comment Share on other sites More sharing options...
mb Posted September 25, 2007 Author Report Share Posted September 25, 2007 Not quite but when you need decking let me know ! Link to comment Share on other sites More sharing options...
Mook Posted September 26, 2007 Report Share Posted September 26, 2007 Blimey - can you deliver as well? Link to comment Share on other sites More sharing options...
mb Posted September 26, 2007 Author Report Share Posted September 26, 2007 I would if only I knew how to tighten up my roof bars... Link to comment Share on other sites More sharing options...
Mook Posted September 26, 2007 Report Share Posted September 26, 2007 Link to comment Share on other sites More sharing options...
flintybob Posted September 28, 2007 Report Share Posted September 28, 2007 [ QUOTE ] Has Anyone bought/used these & what were they like ? Been wondering as seem to be folding the seats down more & more with the new house ! [/ QUOTE ] Try these chaps.. http://www.gttowing.co.uk/ I've got a set of Thule Aero Bars with cycle carriers. Pretty easy to chuck on and off once you've set them up. Link to comment Share on other sites More sharing options...
petevb Posted September 30, 2007 Report Share Posted September 30, 2007 [ QUOTE ] Your best bet is to get some OEM ones - they're not cheap (about £100 IIRC), but they fit better than anything else. [/ QUOTE ] I like the OEM. Fit great, hold on very well, but probably cost you about .2 seconds at the track... Link to comment Share on other sites More sharing options...
