Sponge Posted September 24, 2007 Report Share Posted September 24, 2007 I press the X on the controller and all I get is one flash of the ring. If I press and hold the button it just flashes continuously. Nothing happens when I press the connect button on either console or controller. (The console does it's rolling LED flash, presumably the search, but nothing further happens.) I have tried several sets of new batteries. My other controller connects fine. Any ideas? Link to comment Share on other sites More sharing options...
Dave Posted September 24, 2007 Report Share Posted September 24, 2007 I'm at work, but isn't there a small connect button on the back that syncs the controllers? Link to comment Share on other sites More sharing options...
Sparky Posted September 24, 2007 Report Share Posted September 24, 2007 Battery too low? Link to comment Share on other sites More sharing options...
Thorburn Posted September 24, 2007 Report Share Posted September 24, 2007 To connect the two, press connect on the console, then on the controller while it is searching. Took me a while to get my wireless controller to pair up with my PC wireless receiver after I had been using it with the 360. Link to comment Share on other sites More sharing options...
Dave Posted September 24, 2007 Report Share Posted September 24, 2007 [ QUOTE ] Battery too low? [/ QUOTE ] I think all 4 segments light up in turn for low battery? Link to comment Share on other sites More sharing options...
Chelsea Mick Posted September 24, 2007 Report Share Posted September 24, 2007 Have you tried this....? Make sure all your hardware (console and controller) is turned off..... Press and hold down your button of light (middle button) on your controller until the console switches on It should connect ok then Link to comment Share on other sites More sharing options...
RacingRed Posted September 24, 2007 Report Share Posted September 24, 2007 [ QUOTE ] I press the X on the controller and all I get is one flash of the ring. If I press and hold the button it just flashes continuously. Nothing happens when I press the connect button on either console or controller. (The console does it's rolling LED flash, presumably the search, but nothing further happens.) I have tried several sets of new batteries. My other controller connects fine. Any ideas? [/ QUOTE ] Sounds like initial connection, I had the same problem. There is a tiny white button on the top edge of the controller and another on the front of the XBox. You need to turn on the XBox then press the little white button on it and it will search for the new controller, then quickly activate the controller and press the white button on its top edge to get it to search for the XBox. They should find each other and synch resulting in the number one quadrent of the ring of light being lit on both devices. I found that reading the instructions helps immeasurably when dealing with new toys. Link to comment Share on other sites More sharing options...
Sponge Posted September 24, 2007 Author Report Share Posted September 24, 2007 Thanks for the input, but I've already tried everything suggested (as it states in my post ). The controller won't power on. I press the 'Button of Light' and the LEDs flash quickly once, then nothing. The controller isn't powering up. I've tried new batteries and the batteries from my other controller, which works, and the result is the same. When the controller won't power up, it can't connect. My other controller powers on, switching the console on and off too. But this one doesn't do anything. I came to the conclusion it's faulty and called Currys. I called the number on my receipt and after 5 minutes of navigating their automated system finally got to speak to someone in Delhi. He was no help at all. He told me to call Currys Online - I thought I had! He gave me another number. I called it. They told me to call tech support. I told them they told me to call them. She sounded annoyed. I didn't care. I asked if I could just take the controller back to a shop and swap it. She said yes. I called my local Currys to check the had the stock. I explained the situation and that I wanted a black controller. They said fine, we have them too. So I drove all the way to Currys to then be told they can't give me one off the shelf. They have to open up a console to swap it. However, they don't have any Elites in stock and suggested I go to another branch. Like feck! I telephoned you first to avoid poo like this! Why didn't you tell me all this then? No matter how I argued (politely), they wouldn't budge and give me one off the shelf. Some crap about the system showing extra, or was it fewer, consoles if I swapped with a controller off the shelf instead. I didn't care for their excuses, but they didn't care for my situation. He waffled on about having to go to Prescot, in his own car, on his own time to collect a console. Again, I didn't care. But neither did he. It's all he would do. A total waste of over an hour. Something I wanted to avoid, which is why I made the phone calls first! So now I'm waiting for them to call me later in the week and I'll have to go back out. Do you think Currys train their staff to be so inflexible and unhelpful, or is it requirement of getting the job in the first place? Link to comment Share on other sites More sharing options...
Sponge Posted September 25, 2007 Author Report Share Posted September 25, 2007 I collected my new controller this evening. All is well again. They actually processed it as a full console exchange. Link to comment Share on other sites More sharing options...
RacingRed Posted September 26, 2007 Report Share Posted September 26, 2007 [ QUOTE ] I've already tried everything suggested (as it states in my post ). [/ QUOTE ] So you did. Whats wrong with me? Sorry about that Sponge, I wasn't trying to be a tosser. Glad to hear all is well. Link to comment Share on other sites More sharing options...
Sponge Posted September 27, 2007 Author Report Share Posted September 27, 2007 No problem. I appreciate input from people. You never know when you've missed something obvious. So sometimes people stating the obvious is a great help, iykwim. Link to comment Share on other sites More sharing options...
