Rustynuts Posted September 24, 2007 Report Share Posted September 24, 2007 Is there anything on the open market like VagCom, but for Citroen cars? Having finally got round to buying a VagCom cable, I was thinking maybe it would connect with similar software on me van (which has developed a slight misfire when cold). Link to comment Share on other sites More sharing options...
Wobby Posted September 24, 2007 Report Share Posted September 24, 2007 I've only heard of VAG COM that can do all the graphs and fancy logs type stuff. I bet its the wiring in the head, buggers them PD engines! I cant be any help, so i thought i would just be silly Link to comment Share on other sites More sharing options...
techieboy Posted September 24, 2007 Report Share Posted September 24, 2007 I think your Citroen will use the standard OBDII diagnostics port and error codes so there are probably plenty of diagnostic apps out there. I've used Scantool before on my VX220 and it worked a treat and supports most vehicle manufacturers. Not as feature packed as Vag-Com for making changes but does the basic fault code reporting/clearing okay. Link to comment Share on other sites More sharing options...
Wobby Posted September 24, 2007 Report Share Posted September 24, 2007 I think Rusty is after something that can run logs and measuring blocks etc, so he can find a slight fault. And he's just a big kid like the rest of us Link to comment Share on other sites More sharing options...
Rustynuts Posted September 24, 2007 Author Report Share Posted September 24, 2007 Wobby, when did Citroen start using PD technology? Silly boy. See me after lessons please. Techie, is there any software as such that I can grab and use with my laptop (and VagCom cable), or do I need a generic scan tool for the job? Link to comment Share on other sites More sharing options...
techieboy Posted September 24, 2007 Report Share Posted September 24, 2007 Sorry, crap link try this for the free Scantool Software which does support logging etc. Link to comment Share on other sites More sharing options...
Tobes49 Posted September 25, 2007 Report Share Posted September 25, 2007 What engine is the Citroen? If it petrol give the VAG-COM lead a try but select OBD/EOBD button from the main menu (it only limited but it might give you enough information) Also it might not work just depends what protocol they use? Link to comment Share on other sites More sharing options...
Rustynuts Posted September 25, 2007 Author Report Share Posted September 25, 2007 It's a 2.0ltr HDi diesel (52 plate) Link to comment Share on other sites More sharing options...
obdii Posted February 18, 2011 Report Share Posted February 18, 2011 as I learn, Lexia-3 don't work with diesel car, especially those selling in China. Link to comment Share on other sites More sharing options...
