H6W - Replacement
zerologic
Just had a front sidelight go again ! Got some Philips Blue Vision in there at the moment and they have lasted well (my A4 usually EATS bulbs!) but before i order another set of the same cab anyone recomend anything else? Also where is cheep to buy from? the one's im lookig at on ebay are £9.99 for a pair.
LED's are nice, but play havoc if you have DIS, they keep bringing up a bulb out fault. There is loads about them in this forum, do a basic search.
This was my worry with LED's and DIS. I have read about it in the past. I guess I will go for the blue Visions again and check out power bulbs! Cheers all 169144-ok.gif
We did work out a solution for using LED DRL's on a B7 RS4 - you just need the correct value resistors (which aren't necessarily the ones recommended by the suppliers - you need a "tame" electronics engineer to halp).
  • 2 weeks later...
What kind of life will i expect to get out of buying lets say Main and Dipped Phillips Blue vision H7s...
Will come to approx £60 delivered..
Also is it a noticed improvement..
Got just norm set up on my Sline..
Seen a full set also on ebay AUDI A4 99> XENON BULBS HEADLIGHT UPGRADE SET HID
£18 delivered ..not too sure about those..anyone bought any of these before..
http://cgi.ebay.co.uk/AUDI-A4-99-XENON-B...1QQcmdZViewItem
Advice much appreciated before i buy some bulbs...
