Screamer Posted October 13, 2007 Report Share Posted October 13, 2007 Hi, First time poster, long time reader. About 6 months ago I bought a 2005 MK5 Golf GTI. Having come from a lightly modified Subaru WRX I felt the golf in standard form was lacking performance so decided to get a remap. After months of research (mainly on this forum) I decided to go for a Bluefin. Installation was straight forward and I couldn't believe how much difference it made. The car has been transformed! Anyway, I've been blasting around for the last couple of months grinning from ear to ear but now the car has developed a fault. I've read on this and other forums that the OEM diverter valve and pressure circulating valve have a habit of failing (especially on remapped cars). I suspect my DV has failed as the car doesn't appear to be holding boost anymore. When you accelerate, the car seems to pull well initially (maybe for first 500 rpm) but then it feels like the turbo isn't doing very much. How can I tell if it's my DV or PCV that's failed? Has anyone else experienced similar issues? Thanks! Link to comment Share on other sites More sharing options...
Mook Posted October 13, 2007 Report Share Posted October 13, 2007 Welcome to Tyresmoke, Screamer Try posting this in the Golf GTI forum and you'll doubtless be inundated with responses! Link to comment Share on other sites More sharing options...
Screamer Posted October 13, 2007 Author Report Share Posted October 13, 2007 Thanks for the tip. Can I move a post or do I have to start a new one? Link to comment Share on other sites More sharing options...
Rustynuts Posted October 13, 2007 Report Share Posted October 13, 2007 I've just reported this post so the mods will have a look. One of them will move it for you, I'm sure. Link to comment Share on other sites More sharing options...
TagnuT Posted October 14, 2007 Report Share Posted October 14, 2007 Have a word with RedRobin see if he can help. I know he fitted a Forge DV. Link to comment Share on other sites More sharing options...
AlexM Posted October 14, 2007 Report Share Posted October 14, 2007 Hi Screamer, It probably is the DV, mine went pretty soon after my remap (also Bluefin). I've replaced it with the Forge one and everything is back to normal. It's a cheap plastic one that comes as standard which is fine for the standard map but once you increase the boost presure it rips. Link to comment Share on other sites More sharing options...
RedRobin Posted October 15, 2007 Report Share Posted October 15, 2007 [ QUOTE ] Have a word with RedRobin see if he can help. I know he fitted a Forge DV. [/ QUOTE ] ....This long thread may have some helpful info: Forge DV for 2.0T FSI No problems with the Forge whatsoever for me to report Link to comment Share on other sites More sharing options...
Screamer Posted October 15, 2007 Author Report Share Posted October 15, 2007 As it turns out Forge Motorsport is just up the road Booked in for next Wednesday. I'll let you know if it sorts the problem out. After some more spirited driving today, I'd like to revise my initial post. The car doesn't appear to be holding any boost at all. Hard acceleration is accompanied by a faint whistling noise (sounds like air is escaping from somewhere). Will booting it around with a suspect DV do any damage? Thanks Link to comment Share on other sites More sharing options...
RedRobin Posted October 19, 2007 Report Share Posted October 19, 2007 ....I've just seen this thread again. Sounds very like a ripped diaphram on the stock DV. Don't drive hard. If your car is DSG, stay in D-mode and don't make the engine rev hard, especially in third gear which is usually the zone for most turbo boost. Please tell us the outcome Link to comment Share on other sites More sharing options...
Screamer Posted October 24, 2007 Author Report Share Posted October 24, 2007 Normal service has resumed Had a new diverter valve fitted at Forge today (only £35 to have fitted)and the car now performs as it should do. I had a good look at the old valve and you can clearly see a small tear. A few people on this forum have mentioned they can hear a whistling noise from the turbo when driving some GTI's and not others. I noticed mine was getting quite noisy before this went wrong so maybe it's a tell tale sign that it's on the way out. Link to comment Share on other sites More sharing options...
RedRobin Posted October 24, 2007 Report Share Posted October 24, 2007 ....Good to hear that all is now as it should be . Thanks for letting us know - It helps others to identify such failures Link to comment Share on other sites More sharing options...
