B5 2.5tdi- cold start problem.
bradw
The car has recently had issues cold starting. It woould crank but nor fire.
It went for a service on Thursday, and friday morning wouldnt start again.
So it went back in for investigation.
It came back that the in-tank fuel pump was buggered.
When they changed the fuel filter it couldnt reprime. Fair enough I thought.
So I came to pick it up from the garage on sat am and it started fine.
My RAC man neighbour came round and asked for sypmtoms- he then unscrewed the air intake pipe and sprayed some carb cleaner right in to it whilst I was turning it over.
Finally it caught and started noisily.
So he concluded that there is air getting drawn in somehow but oddly no fuel is leaking out- so its a one way issue.
SO could this be:
cracked pipe?
dodgy fuel filter?
maybe the garage didnt bleed something when swapping the fuel filter/pump?
All advice greatly appreciated.
Thanks.
well; glow plugs have been changed, and it STILL wont start.
There's fuel coming from the tank pump, thru the filter- but no further..
It's worringly looking like the injection pump could be a fault (again frown.gif )
I'm really beginning to regret buying this car now.
So fuel not getting to the injectors.
You could try bleeding at the injectors, maybe airlocked
Just had a thought, is the electric stop on the pump oparating correctly..
Guest
Reply to this topic...
  Only 75 emoji are allowed.
