Joylove Posted October 21, 2007 Report Share Posted October 21, 2007 When I open my boot I get water pouring in from the lamp access cover on the lid. Is there a known fault with the drainage or do I have a problem with my seals? Quote Link to comment Share on other sites More sharing options...
Ska Posted October 21, 2007 Report Share Posted October 21, 2007 not heard of anything like that before; proly the lamp seals Quote Link to comment Share on other sites More sharing options...
SneakyMcC Posted October 21, 2007 Report Share Posted October 21, 2007 I had/get water in the bottom of the battery well.... Quote Link to comment Share on other sites More sharing options...
Joylove Posted October 21, 2007 Author Report Share Posted October 21, 2007 [ QUOTE ] I had/get water in the bottom of the battery well.... [/ QUOTE ]Yes I have this too Quote Link to comment Share on other sites More sharing options...
Oli18 Posted October 22, 2007 Report Share Posted October 22, 2007 [ QUOTE ] When I open my boot I get water pouring in from the lamp access cover on the lid. Is there a known fault with the drainage or do I have a problem with my seals? [/ QUOTE ] I had water there when i bought the car but that was because the rear n/s cluster on the bootlid had a crack in it. I replaced it and when you take it out, you can see that the fit between the light cluster's rubber (which was quite dry i must say) and the metal of the boot needs to be quite tight. I would recommend taking the cluster out and really lubricating the seals first and see if that helps. Good luck! -Oli Quote Link to comment Share on other sites More sharing options...
