dadeejay Posted November 24, 2003 Report Share Posted November 24, 2003 Hi all! This is the first time I write on this forum (registered on this morning...) and I'm from Italy where the R32 is an extremely rare object... By the way the % of color is the opposite registered here: only silver and black R32s are delivered and the deep blue ones coem from parallel importers (is it right...? yes...? ) Well... what about mine? The problem is: if I stay at 1000 rpm, gear in neutral, the engine vibrates, not a lot, but in enough to worry me... I also feel vibrations, randomly generated, at the minimum... Is it normal for you or is only a problem of my car? My VW authorized center says it could be a coil that sometimes, at the low revs looses some hit and then the engine go 5 cylinders... Shoul I worry?????? For now it's all... Bye!!!!! Quote Link to comment Share on other sites More sharing options...
Gti_Fly Posted November 24, 2003 Report Share Posted November 24, 2003 Yes worry if a coil pack is gone wrong. But if it is a coil pack then normally you should get a warning light in your dashboard light up! Something is wrong with your car, as these cars should not shake at idle! Have your dealers managed to plug their dianostic computers in to see what is wrong? Quote Link to comment Share on other sites More sharing options...
dadeejay Posted November 24, 2003 Author Report Share Posted November 24, 2003 Yes but the OBD says everything's ok, the EPC doesn't lit on and everything seems regular... After the check the memory was reset and the only thing I noticed is that the urban fuel consumption dropped from 20-22Lt./100km to 15-16Lt./100km and that's fine but these vibrations still remain... on the other side the car goes very well, I think, Last week on a higway i saw 250 km/h (oh, sorry... you use mph let's say about 155-160 mph?) and I had to leave the gas because I had to brake, but felt something yet to have from the engine... Another thing I notice is that if I push all the accelerator down under 2000 rpm I see some kind of embarassment getting revs and going out of the mud of the low revs... In any way you confirm me that no one here has seen a behaviour like this...? tnx..... Quote Link to comment Share on other sites More sharing options...
s4dreamer Posted November 25, 2003 Report Share Posted November 25, 2003 Hi dadeejay, weilcome to Tyresmoke! I was sitting in my car yesterday morning waiting for the ice to melt off the windscreen, and noticed a slight vibration at around 1000-1200rpm. There was no vibration at idle speed and no vibration above this engine speed. I don't think it is anything to worry about (although I must admit that at first I thought the car was misfiring). Trev Quote Link to comment Share on other sites More sharing options...
dadeejay Posted November 25, 2003 Author Report Share Posted November 25, 2003 WHEW Thank you very very much for giving it a try!!! Now could someone else try the same and see if it is a peculiarity or a problem? bye!! Quote Link to comment Share on other sites More sharing options...
shao_khan Posted November 25, 2003 Report Share Posted November 25, 2003 I'll keep an eye out - mine is cold starts and short runs in the morning, so I guess should be suceptable, wil let you know. Quote Link to comment Share on other sites More sharing options...
