jcarm Posted November 30, 2003 Report Share Posted November 30, 2003 I am losing hydraulic steering fluid. Inspection of steering rack does not indicate that I am losing fluid from the rack piston. Leak appears to be near the center of the rack due to oil dropping on from of cat. conv. Any ideas? Quote Link to comment Share on other sites More sharing options...
Edd_W Posted December 8, 2003 Report Share Posted December 8, 2003 common fault on earlier cars. The internal seals fail and the fluid leaks out of the gaiters. Quote Link to comment Share on other sites More sharing options...
jcarm Posted December 8, 2003 Author Report Share Posted December 8, 2003 Forgot that info. 1995 quattro. Also, do you know if a VW rack is interchangeable? VW parts seem to be quite a bit less expensive. Thanks Quote Link to comment Share on other sites More sharing options...
Edd_W Posted January 2, 2004 Report Share Posted January 2, 2004 Very unlikely, the only possiblity is the early passat 92 to 97 series but I think it highly unlikely to fit. I would take you rack off and take it to someone to re-condition. Euro car parts or German and swedish may do an exchange service. Where are you? Quote Link to comment Share on other sites More sharing options...
jcarm Posted January 5, 2004 Author Report Share Posted January 5, 2004 Northeast U.S. Connecticut Quote Link to comment Share on other sites More sharing options...
Edd_W Posted January 6, 2004 Report Share Posted January 6, 2004 You will be best to find someone mail-order to supply a replacement rack. Quote Link to comment Share on other sites More sharing options...
jcarm Posted January 12, 2004 Author Report Share Posted January 12, 2004 I did spend 6 mos. on Jersey (UK) Cheers Quote Link to comment Share on other sites More sharing options...
