M005 Posted December 1, 2003 Report Share Posted December 1, 2003 Had my MY2000 A4 TDI about a month now and noticed this morning that the passenger footwell was soaked in water after the weekend's deluge. I am guessing this is the drain holes under the bonnet blocked, but where are they? My Audi 'specialist' thinks that it is under the battery, but isn't sure Looks like I'll have to tackel this one dark evening, so any help on location would be appreciated. Quote Link to comment Share on other sites More sharing options...
Big_Dan Posted December 1, 2003 Report Share Posted December 1, 2003 Should have stuck with Land Rovers ... at least you expect them to leak Quote Link to comment Share on other sites More sharing options...
M005 Posted December 1, 2003 Author Report Share Posted December 1, 2003 Still have the 110 - which does leak despite gallons of sealant Quote Link to comment Share on other sites More sharing options...
M005 Posted December 2, 2003 Author Report Share Posted December 2, 2003 Drain 'diaphragm' is centrally located below the battery. You do need to strip down the plastic trim surrounding the battery, but do not need to remove the battery. Simply unbolt the cradle and tilt it, there is then just sufficient room to get your hand in to clear the diaphragm out. Loads of leaves, twigs and silt clogging it up - now I just have to get the carpets dried out Quote Link to comment Share on other sites More sharing options...
