Glove box CD Changer and the RNS-E Sat Nav
deviseruk
I have brought a Glove Box CD Changer to go with my RNS-E Sat Nav. Is it easy enough to modify and fit the CD Changer into the glove box, or do I buy a glove box with the housing instead?
Do I also need to do anything to the Sat Nav to tell it has a CD Changer, or is it as simple as plug-and-play?
Thanks
Craig
You can mod your current glove-box, but it all depends on your DIY skills, but if you what a pro looking installation then replace the glove-box, I think they are around £150.
You will need to buy the CD-Changer wiring harness. It's not quite plug & play on the wiring side, but it's not that hard if you have the wiring diagram.
You don't have to recode the RNS-E for the CD-Changer to work, but if you can get access to vag-com to recode the RNS-E, then that would be the best option 169144-ok.gif
You need an application like vag-com www.ross-tech.com
Here is the (CD-Changer) coding options for the RNS-E, so you would change the last number of the coding, so if you have CD-Changer & Multifunction Steering Wheel, then change the last value to 7
0xxxxx?: Options II
1 - default
2 - TV-Tuner
3 - CD-Changer
4 - TV-Tuner and CD-Changer
5 - Multifunction Steering Wheel
6 - TV-Tuner and Multifunction Steering Wheel
7 - CD-Changer and Multifunction Steering Wheel
8 - TV-Tuner, CD-Changer und Multifunction Steering Wheel
Thank-you for this, I will have to have a play when I get time.
I haven't got the Multifunction Steering Wheel, didn't have it on my last A4 so not missing it. Missing the DIS though, infact missing a lot of little extras which I read on the forum have been retro fitted.
I have taken apart my glove box to see how to fit the CD-Changer. I could make the hole no problem, just can't see how to supoort the back of the unit.
Has anyone done this before, and just in case, how can I find out the Part Number of the proper Glove Box with CD-Changer Housing?
Before I put my car back together, I have been reading from various sources regarding the installation of the RNS-E.
Upgrading the Revision Level of the RNS-E. Where do I get an update from and how do I do it?
I am getting lost about the CAN Bus and the GALA V Signal. I have fitted the RNS-E Adapter and RNS-E Adapter + Diveristy Antenna Adapter, but do I need to do anything with the CAN Bus or something to tell the car it now has a RNS-E, and do I need to connect to the GALA V Signal? If so, where do I connect these to and from?
Where is the best place for the GPS Antenna?
Any help would be most appreciated.
I have got two questions that are probably going to be really simple to answer...
The adapter for the RNS-E, the big plug for the RNS-E has got two blue stips on the connectors which prevent it from plugging into the RNS-E. Is this right? If so, have I got the wrong adapter or is there something I'm suppose to do?
Next question, the CD Changer lead, where does the white plug go in to the RNS-E?
Thanks
Craig
