Turn left on Red
Chav
the only drawback is that pedestrians and cycylists have right of way (ie: The green walk sign) when you are turning right which can lead to some close shaves, then again pedestrians and cycylists are expendable smirk.gif
So I noticed when I almost got mowed down crossing the road last time I was in Uppsala.
like everything else over there, the roads are quite wide in the US - Mistakes can be forgiving, as you have more space to maneuver - if things went belly up. I think over here, the roads aren't so forgiving and small - the tiniest mistake can be punished with an airbag in yer face. Well, that's my opinion of it.
Disagree on that one. Overtaking in any lane doesn't make more sense than only on the right.
Knowing that a car should pass you only on the right is better than knowing it could be on either.
The reason our way doesn't always work is it requires lane discipline, i.e. moving over to the left when you've finished overtaking. And people don't.
Hmm. We have a turn left on red after stopping on quite a few (not all) intersections down under.
It seems to work quite well, even if adjacent to a pedestrian crossing.
Mind you apparently speed kills (so we are endlessly told) so no one goes through them faster than 10km/h. wink.gif
I agree it'd be a good rule, but I doubt our great British drivers could cope... tongue.gif
Not one to be sexist but most women confuse "green" means go with "green" means hastily pack away the make up..then go. So how the hell will they cope with being able to move when the light is red confused.gif
