Dave Posted January 8, 2008 Report Share Posted January 8, 2008 Can some-one please remind me.. I want to network two PC's.. do i need cross over or straight? Thanks Link to comment Share on other sites More sharing options...
Cupramax Posted January 8, 2008 Report Share Posted January 8, 2008 cross over if your not using a hub. Link to comment Share on other sites More sharing options...
Dave Posted January 8, 2008 Author Report Share Posted January 8, 2008 Is it different if i'm using a router? Link to comment Share on other sites More sharing options...
RobK Posted January 8, 2008 Report Share Posted January 8, 2008 I presume you mean a broadband router with built in switch? If so it's a straight through cable. Link to comment Share on other sites More sharing options...
Dave Posted January 8, 2008 Author Report Share Posted January 8, 2008 Sorry Rob, It's a 4 way router with 3 PC's.. internet access is via wireless. So PC's 1, 2 and 3 all connect to each other via a 4 way router. (it's actual term on the box is 4 way Ethernet switch) Link to comment Share on other sites More sharing options...
Dave Posted January 8, 2008 Author Report Share Posted January 8, 2008 What's the easiest was to set them up.. just allow permissions on each, or use one as a server? Link to comment Share on other sites More sharing options...
RobK Posted January 8, 2008 Report Share Posted January 8, 2008 It's only a crossover cable if you're connecting 2 PCs together directly, so in your case you need straight through cables from each PC to the switch. For 3 PCs I'd just share the data out on each one. If you start adding more PCs it would be simpler to have one as a server. Link to comment Share on other sites More sharing options...
Dave Posted January 8, 2008 Author Report Share Posted January 8, 2008 Thanks Guys! Link to comment Share on other sites More sharing options...
