Light knocking/rumbling, not suspension
JonK_UK
What a site! bowdown.gif My latest fix-it question -- Over small bumps, sometimes even normal road surfaces, I'm getting a light rumble from the front end. It disappears when I'm on the brakes, so I've rules out suspension wear. On inspection, suspension components looked fine.
I've just had the front discs skimmed and fitted new front pads due to a rattling caliper, yet the problems still there. Any offers as to where to look next?
Cheers beerchug.gif (97 4.2 Q)
Sure thing. The mystery is that the knocking disappears when the brakes are applied. Wheel bearings, suspension wear etc. would carry on making a noise all of the time I would think. Perhaps the discs need replacing at the next service altogether as they looked tired. Pads are new. Skimming improved the surface, but perhaps they're worn and rattling...
When you are braking the loads on the suspension increase and any slight play is normally taken up, so don't rule out suspension. Best thing is to jack up the front, then poke prod pull push and lever all the links looking for movement. You may need to put a lot of force in to find it. Personally my favourite would be the sway bar links as mine made a little rumbly rattle and after I changed them it was sweet...
Thanks for this, I hadn't thought of that. Replaced one of the roll bar links, the other felt ok. I think come service time in the spring, I'll have to crow-bar my way around and check all the links. With 4 per side, and some done recently, it can be really difficult tracking down the worst offenders.
There's a 'u' shaped bracket that connects two of the suspension arms and it's like a thump over little bumps in the road, I thought something was loose in the boot for a couple of weeks. They're not expensive (30 quid ish) and pretty easy to replace (had the garage do mine).
Might be worth looking into that.
I think thats the anti-roll bar drop link you're referring to there.... same problem I had.
Note there are two types - one is rubber bushed (later style) and the other has ball joints (earlier type).
Readily available on ebay for under £20 a pair...
Like these ones:
http://cgi.ebay.co.uk/Front-Antiroll-Bar...1QQcmdZViewItem
The earlier ones are a swine to remove as the balljoint fouls the wheel hub bearing carrier - in the end I dremeled mine off....Easy!
I just did mine last weekend.
(These I mean)
The old ball jointed ones only need the botton shock absorber bolt removed. The tough bit was sliding the new bolts through. but that was now real prob once I check on PaulW's audipages.
Edit:
Wheel bearing problems normally make more noise when the wheel is loaded i.e. more noise when turning right = front left bearing is going. They can rumble on getting progressively worse over time.
When they first start to go, applying the brakes clamps the disk vertically, so reducing the amount the wheel can wobble. This will reduce the rumbling.
The other explanation could be a warped disk.
Steve
  • 2 months later...
FINALLY TRACED!!!!!! Jeez this has been a real issue. Now that I have replaced:
pads,discs, tie rod ends, track rod, c links, and a wheel bearing.
It seems the rattle has been located in the O/S Brake Caliper Carrier. The part is really worn and rattles like hell unless you apply the brakes even very very lightly to take up the clearance. Got a replacement from a breaker, going to fit on Friday. I really hope that's it -- not much else to actually replace.
