ant Posted January 13, 2008 Report Share Posted January 13, 2008 i've not got a handbook and need to know the front weight figure of an A8 also the rear weight figure. cheers ant Link to comment Share on other sites More sharing options...
ant Posted January 13, 2008 Author Report Share Posted January 13, 2008 oh its 3.7 Link to comment Share on other sites More sharing options...
IT_S8 Posted January 13, 2008 Report Share Posted January 13, 2008 The weights in KG for your specific car are on the build sticker - in the service book on the sticker in the front, or on the sticker in the spare wheel well. It will be around 1800KG. Link to comment Share on other sites More sharing options...
LostKiwi Posted January 13, 2008 Report Share Posted January 13, 2008 Didn't we cover this already here? http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/1266724/an/0/page/6#1266724 Allow around 100kg less for fwd as opposed to 4wd with around 60=70% of that coming off the rear axle (at a guesstimate). Link to comment Share on other sites More sharing options...
ant Posted January 14, 2008 Author Report Share Posted January 14, 2008 forgot about that topic sorry, but i need the weight per front wheel for 3.7 d2 i have no og service book and the sticker in the spare wheel well doesn't have the weights on. Link to comment Share on other sites More sharing options...
ant Posted January 14, 2008 Author Report Share Posted January 14, 2008 the reason i ask is that i'm double check that the air struts that i've been supplied are up to the job.... i've been searching on the internet for hours and found nothing..... any help would be gratefully received Link to comment Share on other sites More sharing options...
PsYcHe Posted January 14, 2008 Report Share Posted January 14, 2008 Don't think you can get weight per wheel unless you go to a weighbridge, I can only find total weight and f/r distribution. Link to comment Share on other sites More sharing options...
LostKiwi Posted January 14, 2008 Report Share Posted January 14, 2008 For a 4.2Q... From the weight distribution and kerb weight figures I manged to find (60/40 front bias on 1750kg kerb weight) it should be around 525kg per front wheel and 350kg per rear wheel, depending on spec. Therefore to guesstimate the 3.7: Engine weight will be broadly the same, gearbox and front diff the same but then remove the transfer box, rear diff, axles and driveshafts (probably around 100kg). Since some of that weight will also be carried by the front wheels (sitting as it does in front of the rear wheels) we can reasonably safely guesstimate 30-40kg on the front axle and 60-70kg on the rear less than the 4.2. Is that close enough? Link to comment Share on other sites More sharing options...
ant Posted January 14, 2008 Author Report Share Posted January 14, 2008 cheers for that i'll let you know Link to comment Share on other sites More sharing options...
