Bad experience Doncaster Audi
Veracocha
A friend took his A3 1.9Tdi to Doncaster Audi sor a service and cambelt change.
When he drove his car out, the turbo wasn't engaging and it was very slow. He called Doncaster to advise the situation and was told that this couldn't happen due to the checks they carry out after service. My friend then went to Stafford Audi who were more helpful. He dropped the car off and they found that the turbo had not been reconnected, the timing was out and the belt had been put on 1 tooth out.
Also he has a warrantee which advises the CAT is covered. It needed replacing and he was charged £600 because apparently it is covered but not for corrosion.
All in all not good from an Audi Dealer.
Interesting, I had wondered about using Doncaster instead of York if I need anything - although they are further away I had heard they were better. York just pees me off every time I go there - had a number of experiences where they have given the car back and the fault has not even been fixed.
  • 3 weeks later...
I found Doncaster to be very good when I needed new brakes. I asked for all 4 to be replaced and the head tech told me that they didn't all need doing and said I could save a bit by just replacing the front discs.
