Ritey Posted December 2, 2003 Report Share Posted December 2, 2003 Hello all, Recently purchasing a wonderful phase 2 GTI Polo however I can't figure out how to turn of the traffic report feature on the radio, its interrupting my charma!! Can anyone help as the manual I have is for a beta radio! Just need to know how to turn the damn thing off Thanx Quote Link to comment Share on other sites More sharing options...
shao_khan Posted December 2, 2003 Report Share Posted December 2, 2003 the easiest way is to turn the radio onto AM and then back to FM - usually works the trick. Welcome to the forum BTW. Quote Link to comment Share on other sites More sharing options...
Ritey Posted December 3, 2003 Author Report Share Posted December 3, 2003 Hello, Yeah I've tried that, it stops the annoucment but it doesn't actually turn the tp off completly, any other ideas?? HELP!!! Quote Link to comment Share on other sites More sharing options...
shao_khan Posted December 3, 2003 Report Share Posted December 3, 2003 Oh - that works on mine!!!!! Quote Link to comment Share on other sites More sharing options...
Ritey Posted December 4, 2003 Author Report Share Posted December 4, 2003 Ok so i've been down the local VW dealer and they have said the same, but can't show me because there too busy! Could you explain a litte more, do you have to be on the main radio or tp radio stations? Quote Link to comment Share on other sites More sharing options...
shao_khan Posted December 4, 2003 Report Share Posted December 4, 2003 You need to be on an FM radio station to have TP work, so if you press the AM button or frequency select button until you get to FM then this should deactivate TP. When you go back to your chosen station TP should not come on again unless you press the TP buton. Quote Link to comment Share on other sites More sharing options...
Ritey Posted December 4, 2003 Author Report Share Posted December 4, 2003 Ok i've done that, does the tp on the lcd always show, or does that mean its still on, (top left corner) ??? Thanx 4 ur help Quote Link to comment Share on other sites More sharing options...
shao_khan Posted December 4, 2003 Report Share Posted December 4, 2003 I cant remember off hand - mine shows on the left side of the screen. and disappears when its off. I'll check later when I get to the car. Quote Link to comment Share on other sites More sharing options...
Andrew Posted December 4, 2003 Report Share Posted December 4, 2003 I had a 2000 Polo with Gamma and I have to say I never worked out how the hell TP worked. What is more the TIM seemed to be just as temperamental. Sometimes TP would come on constantly other times it didn't work even when I wanted it to. Following the manual gave no better results! Quote Link to comment Share on other sites More sharing options...
Crusoe Posted December 4, 2003 Report Share Posted December 4, 2003 I think it's a great feature. You program in the channels you want it to seach for the travle messages and it goes away and collects them so that you can listen to cds and then just hit the TIM button to hear the travle announcements that you would have missed plus it saves you having to listen to some of the dire local radio up here just to hear what's caused a jam. I'll need to check in min to see how i've set it buy from memory there is a tp or ta that comes up on the screen when it's activated, you just use the relevant button (think it has one or more of the tp/ta/tm codes on it to switch it off? If I remember I'll scan in the relevant pages of the manual but it should be simple enough. Quote Link to comment Share on other sites More sharing options...
seylectric Posted May 9, 2004 Report Share Posted May 9, 2004 Did anybody ever figure this out, because I have the same problem. "TP" seems to be permanently set, and with this on the radio tunes in to the nearest strongest signal, which is the local station even though it's not the one I want to listen to, although the one I want is preset - it will hold it once it locks on, but you have to be in a strong signal area, otherwise it swaps straight back to the local station. Once you trun off the ignition though it also swaps back to the local station onvce you start up again. I'm in and out of the car all day so it's really annoying. The traffic program is fine if you are travelling but I'm just driving locally so not much cop to me and not what I want to listen to. It SHOULD be simple enough to switch the function off, but it isn't! I have read the manual backwards, and it says nothing. The main dealers are (surprise surprise) clueless too. Switching from FM to AM and back doesn't work for me. Quote Link to comment Share on other sites More sharing options...
shao_khan Posted May 11, 2004 Report Share Posted May 11, 2004 [ QUOTE ] I have read the manual backwards [/ QUOTE ] Dude you are a brave man. The Gamma in my Bora deactivates TP by switching from FM to AM and back again. I have no idea why the Polo one is different. Quote Link to comment Share on other sites More sharing options...
