E46 M3 Service 3
N3WOB
Thank you fellas, on the basis the last service was an inspection 2 and it seems that involved changing the oil & filters for the sum of £700, I was guessing at some point they may do a proper service and change the plugs, cambelt etc etc & thought that might be called an inspection 3?
Inspection 2 involves a lot more than that - what you are describing sounds exactly like the 'in between' oil service referred to above, which should cost about £200.
You need to ckeck the service book, or contact a BMW dealer to confirm exactly what services the car has had, and thus what is due.
Get this wrong and you will void the warranty, and the M3 engine isn't really considered bullet proof, so that would be expensive..........
Sidicks
Insp 2 is the biggest service and includes spark plug change, E46 BMW's are Chain driven so do not need the cambelt changed.
Cheers Gav
