cruise controlo problem
FBFsussex
y'know its all to often that you buy a car and soon enough someone has a problem with its cruise control not working. it seems to happen to every model near enough, now my A8 has the problem. it just wont work, it has worked 2 or 3 times but its intermittent and i can mess with it for hours on a trip and njot get it to work. ive read the manual and i know im using it right.. is there a fix? a reset tool maybe?
any advice welcomed
Dan
The stalk switches are known to fail. You could try a contact cleaner in the switch but more than likely it'll be a replacement switch. One thing that has been noticed in the past is that the more its used the more likely it is to keep working! So on that basis keep playing with that switch...
I had the same problem with my facelift S8. I think that the problem is caused by the wire breaking due to flexing rather than dirty contacts. In any event mine was cured by fitting a new control arm. As I recall the new stalk was about £85 and the job took me about an hour (steering wheel/airbag has to come off). If I had done the job before would have only taken me about 30 mins. See this article for info http://www.audipages.com/Tech_Articles/electrical_equipment/cruiseswitchreplace.html . The facelift cars are slightly different but the info is close enough (or it was for me).
