Plastx on satnav screen ?
cabby
Hi Cabby,
I used Plastx on a mobile phone, it had the LCD display behind a sort of hard, clear, plastic exterior. It worked fine there. But if the screen is softer, say like and LCD screen on a laptop i worry it might not work to well.
I just find its hard to use in small areas as its tough to break down, the cleaners in it are quite strong so it might leave some fading.
Your best bet is to check with Meguiars. They have a helpline number that is open pretty much all day and evening as it just diverts you to the USA (at extra charge to you). They are very helpful and can give you a yes or no be sure!
Geoff
  • 2 weeks later...
Hi there!
I'm about to paint my rooms and now choosing appropriate colors.
Found program to pick painting colors right on the photos of interior
or house facade, here's link : http://www.housepaintcolorschemes.com
Think it will help you too.
And by the way, if you wish to exchange photos in the format of this program,
please write me at: greensandra DOG gmx DOT com
Cheers,
Sandra
Hi Sandra,
Before you merrily apply your lovely egg shell finish to your walls I would strongly recommend claying them initially (Megs Quik clay together with some speed detailer would do them proud. (allow for better paint adhesion)
Then thoroughly wash your walls down (two bucket method and lambswool mitt no less) and dry with a fluffy MF cloth.
This will better prepare your walls for painting 169144-ok.gifbike.thumb.gif
