swan7 Posted March 17, 2008 Report Share Posted March 17, 2008 [2001 - GOLF GT TDI 115 - 85k] Evening all, Got another stange problem with my Golf - this time the speedometer seems to have a mind of its own (seems to happen a lot with my car!). When idle or in motion, the speedometer needle jumps aound various mph (revs are constant) ie. when idle the needle moves quickly between 0-80mph or when driving at eg. 70mph, needle moves between 0-120mph. On occasion it just sticks at 0mph. So, any ideas on what causes this problem and more importantly, possible solutions (inc. parts/costs?). Cheers. Link to comment Share on other sites More sharing options...
shao_khan Posted March 17, 2008 Report Share Posted March 17, 2008 My TT had a similar problem - that resulted in a new dash pod as they arent really fixable by joe public (audi do refurb them) - so it could be that as worse case scenario. Not sure on repair options - new dash pod from a scrappy? Link to comment Share on other sites More sharing options...
S3Bangs Posted March 17, 2008 Report Share Posted March 17, 2008 I had this happen once or twice on my S3, I traced the speed sensor clip on the engine mounting, undid/took it out, reseated it and that was it Can't say if this will work for you, but give it a try as your first port of call Link to comment Share on other sites More sharing options...
swan7 Posted March 18, 2008 Author Report Share Posted March 18, 2008 Where is the 'speed sensor clip' on the Golf, and what does it look like? I am hoping this is something I can sort out myself, and would appreciate some guidance on what to do. Cheers. Link to comment Share on other sites More sharing options...
S3Bangs Posted March 19, 2008 Report Share Posted March 19, 2008 [ QUOTE ] Where is the 'speed sensor clip' on the Golf, and what does it look like? I am hoping this is something I can sort out myself, and would appreciate some guidance on what to do. Cheers. [/ QUOTE ] Oooh..big question that!! Ok, on my R, I had a look and if you stand right in front of the engine bay, towards the rear right, i.e to the left of the airbox (I hope this makes sense as I dont have a pic) is a sort of empty space. Look down towards the engine block and you should see a small silvery heat resistant bit that covers the clip on the engine. You will need a small screwdriver to undo the clip, however, dont force it as you might break it. Just prise it. I'll try and find a pic to explain better if I can. Link to comment Share on other sites More sharing options...
S3Bangs Posted March 19, 2008 Report Share Posted March 19, 2008 Ok..found this pic and put an arrow slightly above (about an arms length) where I found it on the r. I'm thinking yours would probably be in the same place Clip looks something like this Link to comment Share on other sites More sharing options...
swan7 Posted March 19, 2008 Author Report Share Posted March 19, 2008 Thanks for the pic - will try it out. Not sure if this is related to the dody speedometer, but now the 'Please Refuel' warning light keeps coming on even though the tank is half-full and the roads are pretty flat ie. not on a tilt/camber. Seems to happen when changing gear or turning. Any ideas? Link to comment Share on other sites More sharing options...
