Cry for help - ElsaWin users
gtiller
Hi all,
I posted this over on the A6 list, but it gets a bit lonely over there!!!!!
Does anyone have access to ElsaWin?
In particular, I am after instructions on removing the rear bumper of an A6 Avant (type C6)
Your help would be much appreciated!
I used 2005 A6 Avant and guessed the other bits, assuming the bumper fixings would be the same.
There's this picture:
1 - Combi bolt - 23 Nm
2 - Impact absorber
q Removing and installing → Chapter
3 - Cross member
q Remove cover.
q Unscrew combi bolt → Item and pull cross member out of longitudinal members.
4 - Centre support piece
5 - Right support piece
6 - Torx bolt - 1.5 Nm
q Used for attachment of left, right and centre support pieces
7 - Rear cross panel trim
q Unscrew oval head self-tapping screws → Item (6x).
8 - Oval head self-tapping screw - 1.5 Nm
9 - Support piece
q Replace when installing new bumper cover
q Do not release until bumper cover has been completely fitted → Fig.
10 - Cover
q Removing:
– Partially remove luggage compartment trim.
– Unscrew hexagon collared nuts → Item and → Item (accessible from luggage compartment).
– Disengage cover sideways from guide and detach.
– Unplug connectors if applicable.
q Support piece → Item need not be replaced if the same cover is re-used.
q Attaching cover to side panel → Chapter
11 - Guide
12 - Oval head self-tapping screw - 1 Nm
13 - Wheel housing liner
14 - Hexagon collared nut - 6 Nm
q 2x
15 - Hexagon collared nut - 6 Nm
q 2x
16 - Left support piece
17 - Seal
