shadow8 Posted March 19, 2008 Report Share Posted March 19, 2008 Can anyone tell me if there is a fix for a whining AC compressor on my S8 or is it just something one has to tolerate unless replacing it? Thanks Link to comment Share on other sites More sharing options...
Figure11 Posted March 20, 2008 Report Share Posted March 20, 2008 I have this on mine. Not enough to annoy, but noticable. Probably the magnetic clutch, I will live with it as it disapears at speed and change when it becomes intrusive. To confirm it is the clutch just switch the compressor off by selecting recirc. If the noise goes you know what it is. Mike Link to comment Share on other sites More sharing options...
Ska Posted March 20, 2008 Report Share Posted March 20, 2008 After a few months sitting idle my cars started doing this. Will have a look when the weather a bit better. But mine normally whines on cold then goes away once warmed up. Link to comment Share on other sites More sharing options...
PsYcHe Posted March 20, 2008 Report Share Posted March 20, 2008 Ska... Sure that's not just the missus? Mine normally does that, but I find a quick application of heated seat calms it down quickly Link to comment Share on other sites More sharing options...
Ska Posted March 20, 2008 Report Share Posted March 20, 2008 Naah... She whines whether shes in the car or anywhere else for that matter But I do find the compressor clutch whine drowns her out for the first few minutes when she is in the car Link to comment Share on other sites More sharing options...
IT_S8 Posted March 21, 2008 Report Share Posted March 21, 2008 AC Whine will be bearings on the compressor. It only gets worse over time, answer is to replace compressor. Its usually a little squeaky noise, rev related with the A/C on. You can test it by switching the climate to ECON mode, which turns off the A/C, or turn off the climate altogether. I think Mike was having a very rare off moment suggesting Recirc would test the theory Link to comment Share on other sites More sharing options...
Figure11 Posted March 21, 2008 Report Share Posted March 21, 2008 [ QUOTE ] AC Whine will be bearings on the compressor. It only gets worse over time, answer is to replace compressor. Its usually a little squeaky noise, rev related with the A/C on. You can test it by switching the climate to ECON mode, which turns off the A/C, or turn off the climate altogether. I think Mike was having a very rare off moment suggesting Recirc would test the theory [/ QUOTE ] Doh, I meant ECON, I did ....really! Mike Link to comment Share on other sites More sharing options...
shadow8 Posted March 25, 2008 Author Report Share Posted March 25, 2008 Thanks everyone. I'll live with it........price plus fitting of replacement is prohibitive! Link to comment Share on other sites More sharing options...
