strange noise
dobra
please help.
i have a noise that sounds like something is loose under the car and when you brake at low speed and coming to a halt it sounds like the underneath there is a mount coming loose and sounds like rubber to metal squeek.
i think it comes from near the gear box tunnel and slightly in the left side behind the dash. it came to light when i changed a badly worn bottom rear mount on the front near side. it got through mot ok they checked all the norm around the front. i did not mention noise as i needed the mot. is there any gearbox mounts that can do this or has any one had this, just wanted to see if i can be directed to something rather than start sripping it.
