Hudster Posted May 4, 2008 Report Share Posted May 4, 2008 My 2006 A3 only came with one key, and I'd really like to get a second just for emergencies. I've seen in other threads that Audi will charge me £150-£180 for a new flip-key, but is there another option? I'd be happy with a basic non-flip non-remote key for emergencies, I don't really want to shell out nearly £200 for a key that hopefully never be used. Or... are these ebay keys any good? Seen several threads saying they don't work Link to comment Share on other sites More sharing options...
mb Posted May 6, 2008 Report Share Posted May 6, 2008 There are some complicated rules re key-matching - have a look at my post in the vag-com section which suggests only a new key will work with immos 3 or 4 I was lucky as was able to match my keys up myself - the difficulty is getting the "SKC" which is needed - I would imagine being a later generation cluster you can't pull the PIN from the cluster like I did but it may be worth a try as the actual procedure itself was simple. So based on my experience - You will need a NEW key with a transponder chip appropriate to your immo implementation (3 or 4 I think) so that will have to be ordered from Audi The keys will then have to be matched which is a vag-com job IF you can get the SKC otherwise that is a dealer job too HtH Link to comment Share on other sites More sharing options...
