Oil
AlexM
  • 5 weeks later...
Check in the handbook and it'll tell you what oil should be used (VW spec [eg.VW504/507] and weight[eg. 5w 40). I have to say 10w 40 doesn't sound right to me. Contact VW Customer Services, and they'll tell you what oil is required.
Generally, topping up with the same oil spec is required, but no harm in using better oil (full synth into semi) if that's what is available. Topping up with worse oil (semi synth into full) is bad.
Thanks, i didn't think that oil sounded like the right stuff.
My understanding is that the Longlife and Time & Distance services both use 5w - 30 oil. The difference being the that Longlife has a blend of detergents which enables the oil to perform for longer.
The manual says it's VW 501, 502 or 504, i think i should be ok with the Castrol Edge 5W -30 i have in the house
The manual may be assuming your on AVS service, not fixed mileage services.
When I had the S4 I used the same longlife 5w30 rip-off stuff and enquried about changing to fix service to try and stop the horendous oil use (due to the thinness of LL oil). They said the oil used would be standard 10w40 Castrol GTX Magnetex and would require changing every 10,000 miles.
ooohh crap, thats the oil the dealer said to use, this has confused things again. I came off of the long life service as i do under 10000 miles a year. Is it a bad thing to mix oils or should i go and buy 10w 40 to keep it the same?
The price difference between VW504/507 5w 30 and Castrol Magnatec 10w 40 is about £20. Surely it's worth that £20 for a good quality oil instead of that Magna****e stuff?
My S4 was using a litre every 1,500 miles, sometimes more... so anyhting that would help slow the oil use would have been a good thing.
I didn't bother in the end, but was tempted.
Always use the same TYPE of oil... mixing is a terible thing to do... ever tried Ribena with Milk ??? +++
Guest
Reply to this topic...
  Only 75 emoji are allowed.
