tspjano Posted July 13, 2008 Report Share Posted July 13, 2008 Hi, I have a vw passat 1.9 tdi PD, 03 reg. About an hour age during journey starts flashing me warning lamps of anti-lock brake system (abs)and electronic stability program (esp) then after few second glow plugs lamp go on. Since then ABS and ESP lamps are still on and glow plug lamp is flashing. except that car drives and brakes as usualy, but I notice that my brake lights are not working. Can anybody help me? Thanks Jan Quote Link to comment Share on other sites More sharing options...
benjie Posted July 13, 2008 Report Share Posted July 13, 2008 The flashing glow plug light and no brake lights working means your brake light switch is broken, a common fault. The part is around £8-10 and fairly easy to fit. The fact that the other 2 lights came on at the same time may be related - I would fix the brake lights switch first and see if the other lights go away! Here's a guide - VWvortex Forums: DIY - Installing a new brake light switch (without breaking it!) Quote Link to comment Share on other sites More sharing options...
sotty Posted July 14, 2008 Report Share Posted July 14, 2008 I had the same problem, but a found that just cleaning the switch solved it Quote Link to comment Share on other sites More sharing options...
