watteee Posted October 14, 2008 Report Share Posted October 14, 2008 hi,i wonder if any one can help,when i turn my climate control to cold,one side of the car car is freezing and the other is hot even when both are set to cold.its really annoying,is anyone else had this problem,its a 2004 A4 tdi. Quote Link to comment Share on other sites More sharing options...
PetrolDave Posted October 14, 2008 Report Share Posted October 14, 2008 Are both sides showing the same set temperature? The A4 (like most Audis) has a climate control system where the left and right can be separated or linked. Sounds like your may be separated. Quote Link to comment Share on other sites More sharing options...
watteee Posted October 14, 2008 Author Report Share Posted October 14, 2008 yes both sides are the same,both down at 14,driver side blows freezing cold,passenger side blows hot,even when i put both sides up to hot then back down its still the same,it happened before but one day it rectified itself but its went faulty again. Quote Link to comment Share on other sites More sharing options...
PetrolDave Posted October 15, 2008 Report Share Posted October 15, 2008 Check the climate control for fault codes with VAG-COM - sounds like one or more of the motors that move the air distribution flaps isn't working properly. Quote Link to comment Share on other sites More sharing options...
Mook Posted October 15, 2008 Report Share Posted October 15, 2008 Exactly what Dave says I had this problem on a long term loaner. Quote Link to comment Share on other sites More sharing options...
watteee Posted October 16, 2008 Author Report Share Posted October 16, 2008 how do you check this way,im not sure what VAG-COM is,how it works,what to do? Quote Link to comment Share on other sites More sharing options...
Mook Posted October 16, 2008 Report Share Posted October 16, 2008 VAG COM is a piece of diagnostics software that uses a special plug to allow you to plug your laptop into your car's diagnostics - Ross-Tech: Home You might find someone on Tyresmoke who's close to you who could do it for you, or, alternatively, go to your closest Audi specialist and ask them to check for fault codes. Quote Link to comment Share on other sites More sharing options...
