Audi S3 Turbo issue
Dirtbag1981
Hi guys, I have a 52 plate S3 BAM engine 106K, I have noticed an issue with the turbo recently. When I accellerate "occasionially" it lags and the car judders with the engine management light flashing on and off, the turbo works, its just if I wanted to "give it some" it judders or blips intermittently.
Up until now the turbo was lagless and smooth, the car is booked in for a service,the cambelt was done at 85k.
What could the problem be ?
Thanks
A MAF sensor is about £80 if memory serves and can be fitted in less than 5 mins - even by a spanner like me. My TT had the same sort of faults and the MAF sorted it - like driving a different car after it was changed. An Audi dealer should be able to check on their diagnostics for you in minutes.
Yes, the car will have a default set of readings it can revert to should it not get a signal from the MAF - hence disconnecting it is a very straightforward first level diagnosis.
The check engine light flashing sounds unusual - I thought it came on and stayed on until reset?
There are a lot of pipes/hoses on the S3 and hole/loose fit on any of these can lead to the sort of issues you are experiencing. From experience, these dont normally show up on a simple VAG-COM diagnostic check.
Has the car been remapped?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
