Passeta07 Posted October 28, 2008 Report Share Posted October 28, 2008 hello folks My 2001 tdi has developed a problem with the indicators, sometimes they work and sometimes they dont. they also start to work and then just stop or flash really quickly which also makes the relay click just as quick to. On a side not the hazzards work fine and dont miss a beat but i have noticed the indicators seem to work off the same relay switch as the hazzards do! Any pointers appreciated. Quote Link to comment Share on other sites More sharing options...
pontyslapper Posted October 28, 2008 Report Share Posted October 28, 2008 Presume you've checked all the bulbs, fuses etc. If in doubt renew the cheap stuff such as this first - you never know there may be a dicky bulb or a dodgy fuse lurking somewhere? Quote Link to comment Share on other sites More sharing options...
Matt R Posted October 28, 2008 Report Share Posted October 28, 2008 Buy a new hazard light switch+++ Quote Link to comment Share on other sites More sharing options...
Passeta07 Posted October 28, 2008 Author Report Share Posted October 28, 2008 Presume you've checked all the bulbs, fuses etc.If in doubt renew the cheap stuff such as this first - you never know there may be a dicky bulb or a dodgy fuse lurking somewhere? Good point although I know the bulbs are ok because the hazzard lights work unless they have a seperate bulb to the indicators which i doubt. I'll check the fuses tomorrow although i'm sure this isn't the cause either! Quote Link to comment Share on other sites More sharing options...
Matt R Posted October 28, 2008 Report Share Posted October 28, 2008 Part number 3B0 953 235D 01C, The hazard light switch doubles as the flasher relay! £14.54 + Vat Quote Link to comment Share on other sites More sharing options...
Passeta07 Posted October 28, 2008 Author Report Share Posted October 28, 2008 Buy a new hazard light switch+++ I take it this is a whole unit and will solve the indicator problems? If so how much are we talking about to replace? If you've not guessed i dont know much about cars! Quote Link to comment Share on other sites More sharing options...
Matt R Posted October 28, 2008 Report Share Posted October 28, 2008 Easy 2 minute job to replace the switch. Quote Link to comment Share on other sites More sharing options...
Passeta07 Posted October 28, 2008 Author Report Share Posted October 28, 2008 Easy 2 minute job to replace the switch. Cheers matt! Is that a VW part you've quoted? Quote Link to comment Share on other sites More sharing options...
Matt R Posted October 28, 2008 Report Share Posted October 28, 2008 Yeah, i assumed you had a passat:grin: Quote Link to comment Share on other sites More sharing options...
Passeta07 Posted October 28, 2008 Author Report Share Posted October 28, 2008 Yeah, i assumed you had a passat:grin: Yeah ok me stoopid! Quote Link to comment Share on other sites More sharing options...
Passeta07 Posted October 29, 2008 Author Report Share Posted October 29, 2008 Part number 3B0 953 235D 01C, The hazard light switch doubles as the flasher relay!£14.54 + Vat Cheers Matt, it's done the trick. £17.08 altogether, only took 2 minutes to do! Quote Link to comment Share on other sites More sharing options...
