anti freeze advice
rag1873
Make sure you find out what you have in there already and ONLY use that type.
VW's are very particular about the anti freeze they drink - its either G11 or G12.
There's no 'nipping, down Tesco' and buying the cheapest crap on the shelf like you could with a B reg fiesta.
Mix G11 or G12 with anything other than itself and its potentially harmful to the pocket - at the very least you are looking at a full drain of the system and a 'washout'.
There was a thread on this not so long ago. Here you go...
http://www.tyresmoke.net/forum/vw-passat/112874-anti-freeze.html
Edited by pontyslapper
Add link to thread about G12 antifreeze
due to the cold weather was looking at topping up my anti freeze in my passat. any dos or donts before i do it??
Does it actually need topping up? Get your local garage to check it with a Hydrometer (or buy one yourself, they're less than a tenner). This can tell you what the mixture is currently.
